how to parse a CSV file
mhamlett101
Post by mhamlett101 »
what i have is a csv file
example data
2222,aaa,123.45,fffff
33,bb,45.00,gggg
how do i extract the 123.45 and 45.00 on each line?
thanks
Re: how to parse a CSV file
Look at my example below. Save the text of the task to a file and use menu Task->Import to import the task into RoboTask.
You can get an element of standard comma-separated string by specifying its index number starting from 0. For example {MyVar(2)}
Read more about variables here
CatID=INTEGER|1459598804
ExternalName=STRING|"Task54"
ID=INTEGER|833845300
Name=STRING|"Parse CSV text"
Name=STRING|"Set variable ""MyText"" with value ""234,aaaa,00000676,123.45, abcd"""
linecount=STRING|"2"
varname=STRING|"MyText"
varvalue=STRING|"234,aaaa,00000676,123.45, abcd"
varvalue00000001=STRING|"111,bb,00000676,23.00, abcde"
Name=STRING|"Text Loop"
destvar=STRING|"LINE"
line0=STRING|"{MyText}"
sourcetext=STRING|"1"
Name=STRING|"Show ""Full line: """
msg0=STRING|"Full line: "
msg1=STRING|"{Line}"
msg3=STRING|"Price: {Line(3)}"
msgcount=STRING|"4"
