Email alert when subfolder empty
VERDI
Post by VERDI »
Hi, trying to set an alert to tell me when subfolders are empty, and also another alert to tell me when something has been put into the folders. any suggestions?
Use "File monitor" in order to get notifications about new, changed, and deleted files in desired forlder and subfolders.
In order to check empty folder you should use some algorithm like this:
set variable "Status" to "False"
File loop    //on files with subfolders
   set variable "Status" to "True"
   break
end loop
Thus, variable Status will contain "False" value if your folder is empty, otherwise "True".
VERDI
Post by VERDI »
Thanks for the advice, I will try it today.
