Task Entry - override log settings
David W.
Post by David W. »
Is there a way to force a log entry using the 'Log Message' command in a script even when you don't want any others in the log and have the setting for the logs for the Task set to Nothing?
I just want entries in the log that I create.  Maybe there ought to be another log entry type (U) for User log entry.  No?
Thanks
Good idea. We shall contrive something. Thanks.
David W.
Post by David W. »
How are we notified of updates and when will the next one come?  Email, in the program?  Thanks.
So far, RoboTask is performing very well here.
DW
I can write a personal message to you, if you are not objecting.
David W.
Post by David W. »
That will work.  Thanks.
