Excel Arrow Keys
des1
Excel Arrow Keys
Post by des1 »
I am having trouble doing something that I though should be simple, but Excel is not responding properly.  All I need to do in Excel is Paste from the Clipboard, the do the keystrokes below, except the macro will not do anything after it pastes the contents.
PASTE Contents then
{F2}
{LEFT}
{LEFT}
{HOME}
{ENTER}
Thanks,
D-
Excel Arrow Keys
I'm afraid that you are wrong.
In order to paste from clipboard use Ctrl-V key combination.
F2 call edit mode in selected cell in Excell
Excel Arrow Keys
Also, see clipboard actions
des1
Excel Arrow Keys
Post by des1 »
That is exactly what I am doing.  It will not "edit" the cell and move the arrow over two spaces, insert a period, then Enter to save the data after pasting the data.
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|1983895906
ExternalName=STRING|"Task6"
ID=INTEGER|1529657606
Name=STRING|"Paste..."
ActionID=STRING|"A_CLIPBOARD_PASTE"
Name=STRING|"Paste"
mode=STRING|"1"
currentwindow=STRING|"1"
fixedwindow=STRING|"1"
keylayout=STRING|"0"
keys=STRING|"{F2},{LEFT},{LEFT},.,{HOME},-,{ENTER}"
sendkind=STRING|"0"
wincaption=STRING|"Notepad"
hotkey=STRING|"16437"
Excel Arrow Keys
I see.
I think that you want to do exactly the following:
- turn on the edit mode
- insert into cell the data from clipboard
- put the "dot" at two symbols from end of the string
- put the "minus" at the beginning of the string
- save the cell
You should use the such string in "Send keystrokes":
{F2}^(V){LEFT}{LEFT}.{HOME}-{ENTER}
Do not put the line feed into this string, because each line feed simulates the pressing of Enter key. Ctrl-V combination (^{V}) force the pasting from clipboard
see the task below:
;* Do not edit!       *
CatID=INTEGER|1614811947
ExternalName=STRING|"Task409"
Name=STRING|"Paste... (improved)"
keys=STRING|"{F2}^(V){LEFT}{LEFT}.{HOME}-{ENTER}"
sendkind=STRING|"0"
Excel Arrow Keys
Also you can simply remove line feeds from "sending keystrokes" in your task.
Write this:
{F2}{LEFT}{LEFT}.{HOME}-{ENTER}
