Action "TXT Delete line" doesn't work as expected with multiline variables
juanlu
Post by juanlu »
Hi Oleg,
The action "TXT Delete line" has a strange behaviour with multiline variables. The line is deleted, yes, but a new empty line is added at the end of the multiline variable. So the number of lines stays the same instead of being reduced by 1.
Example:
Line 1
Line 2
Line 3
TXT Delete line -> delete line 2
Result:
Line 1
Line 3
<Empty line>
This is not only confusing; if you use this multiline variable in a Text Loop action, you would have a incorrect behaviour (looping through empty values).
Could you please look into this?
Kind regards, Juanlu.
Re: Action "TXT Delete line" doesn't work as expected with multiline variables
It works correctly
Look at my example below. Save the text of the task to a file and use menu Task->Import to import the task into RoboTask.
CatID=INTEGER|693415217
ExternalName=STRING|"Task50"
ID=INTEGER|443491465
Name=STRING|"remove 2-nd line"
Name=STRING|"Set variable ""txt"" with value ""Line 1"""
linecount=STRING|"3"
varname=STRING|"txt"
varvalue=STRING|"Line 1"
varvalue00000001=STRING|"Line 2"
varvalue00000002=STRING|"Line 3"
message=STRING|"{txt}"
ActionID=STRING|"A_TXT_DELETELINE"
Name=STRING|"TXT Delete line"
external=STRING|"0"
line00000000=STRING|"{txt}"
linenum=STRING|"2"
variable=STRING|"txt"
BUT
please note that each line ends with end-or-line symbols
If you want to cut off last EOL symbols use STR trim action
If you use Write Text File action to save text to a file then use "Suppress Trailing End-Of-Line symbols" option
