InputBox not empty Loop
gremlin
Post by gremlin »
Hy,
I try to use a loop with a Input Box.
So now empty or cancel option possible...
It´s a infinity loop, also when I choose "Is not empty"
Anyone had a idea ?
Thanks
Steven
Re: InputBox not empty Loop
Look at my example. It works.
CatID=INTEGER|693415217
ExternalName=STRING|"Task46"
ID=INTEGER|1234854598
Name=STRING|"Loop with input-box"
Name=STRING|"Set variable ""MyVal"" with value ""Some nonempty value to enter to the loop"""
varname=STRING|"MyVal"
varvalue=STRING|"Some nonempty value to enter to the loop"
Name=STRING|"While loop"
operator=STRING|"8"
value1=STRING|"{MyVal}"
Name=STRING|"Input Box"
password=STRING|"0"
prompt=STRING|"Input the walue"
stopifcancel=STRING|"0"
variable=STRING|"MYVAL"
message=STRING|"{MyVal}"
Maybe you made some logical error in your task. May I look at your task?
gremlin
Post by gremlin »
Hy,
sorry your example doesn`t work for me.
I would have a inputbox, with requires a input. No option to skip or empty entry.
Do you have a idea ? I can´t get it work..
Thanks
Steven
Maybe I don't understand your goal...
My example ask you to input some value. If value is empty or you press ESC or Cancel button the task beaks the loop and finish.
Probably you want to realize some other algorithm.
Do you want to skip and continue to enter next value?
How do you want to finish task?
In this case you will have infinite loop...
But you can enter some key-work. For example "end" or "stop" to stop the task
gremlin
Post by gremlin »
Hy,
sorry for my bad description.
I would have a input box which doesn´t accept a empty value.
Thanks
Steven
Maybe something like this:
CatID=INTEGER|799397369
ExternalName=STRING|"Task17"
ID=INTEGER|488131522
Name=STRING|"Input box"
Name=STRING|"Set variable ""MyVar"" with value """""
linecount=STRING|"0"
varname=STRING|"MyVar"
operator=STRING|"7"
value1=STRING|"{MyVar}"
default=STRING|"none"
password=STRING|"0"
prompt=STRING|"Input some non-empty value"
variable=STRING|"MYVAR"
value2=STRING|"None"
Name=STRING|"Show ""You press Cancel button!"""
icon=STRING|"0"
msg0=STRING|"You press Cancel button!"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Show ""Entered value: {MyVar}"""
msg0=STRING|"Entered value: {MyVar}"
gremlin
Post by gremlin »
Hy, thank you for this sample.
When I press cancel , the Popup tell me "I press cancel". Thanks good.
But the Task end.
I need a loop. Where a empty or "cancel" option are not possible.
This is my Task:
CatID=INTEGER|720234516
ExternalName=STRING|"Task15"
ID=INTEGER|953570178
Name=STRING|"Rechnungsnummer"
Name=STRING|"File Loop"
date1=STRING|"20230123"
date2=STRING|"20230123"
destvar=STRING|"PDFDATEIEN"
DuringMinutes=STRING|"1"
file0=STRING|"c:\Sharepoint\Schreiner GmbH & Co. KG\Strandkorb-King - Dokumente\Scan\PC-BUERO1\*.pdf"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
Name=STRING|"Run ""msedge.exe ""{PDFDATEIEN}"""""
ifnonzero=STRING|"0"
params=STRING|"""{PDFDATEIEN}"""
program=STRING|"C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe"
runas=STRING|"0"
wait=STRING|"0"
Enabled=INTEGER|0
connection=STRING|"1"
operator=STRING|"7"
value1=STRING|"{RECHNUNGSNUMMER}"
password=STRING|"0"
prompt=STRING|"Rechnungsnummer:"
variable=STRING|"RECHNUNGSNUMMER"
Enabled=INTEGER|0
ActionID=STRING|"A_MISC_KILLAPP"
Name=STRING|"Terminate process ""C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe"""
more=STRING|"2"
process=STRING|"C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe"
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
destdir=STRING|"c:\Sharepoint\Schreiner GmbH & Co. KG\Strandkorb-King - Dokumente\JTL2Datev\ek-belege original\"
f_count=STRING|"1"
file0=STRING|"{PDFDATEIEN}"
hidden=STRING|"1"
ifexists=STRING|"0"
move=STRING|"0"
rename=STRING|"1"
renamemask=STRING|"{RECHNUNGSNUMMER}.pdf"
subdir=STRING|"0"
system=STRING|"1"
Name=STRING|"Set variable ""RECHNUNGSNUMMER"" with value """""
varname=STRING|"RECHNUNGSNUMMER"
Name=STRING|"Delete File"
Count=STRING|"1"
deletedirs=STRING|"0"
deletereadonly=STRING|"1"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
ToRecycleBin=STRING|"0"
Name=STRING|"File Monitor"
UniqueID=INTEGER|-2004472469
chg=STRING|"0"
chga=STRING|"1"
chgsl=STRING|"1"
chgsm=STRING|"1"
chgtl=STRING|"1"
chgtm=STRING|"1"
del=STRING|"0"
folder1=STRING|"c:\Sharepoint\Schreiner GmbH & Co. KG\Strandkorb-King - Dokumente\Scan\PC-BUERO1\"
foldercount=STRING|"1"
incmask=STRING|"*.pdf"
interval=STRING|"15"
listmode=STRING|"1"
mon_files=STRING|"1"
mon_folders=STRING|"0"
new=STRING|"1"
notsavestatus=STRING|"0"
pass=STRING|"0"
passmode=STRING|"1"
required=STRING|"0"
saveresults=STRING|"0"
subfolders1=STRING|"0"
