Another enhancement request
pathfinder
Post by pathfinder »
This should be the last one! For now.
When you delete a step why does it scroll you all the way to the top? I wish it
would leave you where you deleted the step. Also when you create a step it
scrolls the step you created to the bottom of your view.
In essence stop robotask from scrolling the window. If I want to scroll up or
down I will do it.
This also only happens on large tasks.
Thanks,
John
pathfinder
Ok also in the edit task window when you modify a step, that
step jumps to the bottom of your view.
Man that edit task window does not like to sit still
pathfinder
Here duplicate a if thin statment, then modify an e-mail task. Then delete a step. You will see what I am talking about.;**********************;* RoboTask Task file *;* Do not edit!       *;********************** [Root]ActionAfterRun=INTEGER|0Actions=FOLDERAutomat=INTEGER|-1CatID=INTEGER|0ContinueOnError=INTEGER|1Events=FOLDERExternalName=STRING|"Task3"Hide=INTEGER|0ID=INTEGER|1648266511Name=STRING|"Update Mars Files"Priority=INTEGER|3RunOnClose=INTEGER|0RunOnStartup=INTEGER|0ToLog=INTEGER|3[Actions]Action1=FOLDERAction10=FOLDERAction11=FOLDERAction12=FOLDERAction13=FOLDERAction14=FOLDERAction15=FOLDERAction16=FOLDERAction17=FOLDERAction18=FOLDERAction19=FOLDERAction2=FOLDERAction20=FOLDERAction21=FOLDERAction22=FOLDERAction23=FOLDERAction24=FOLDERAction25=FOLDERAction26=FOLDERAction27=FOLDERAction28=FOLDERAction29=FOLDERAction3=FOLDERAction30=FOLDERAction31=FOLDERAction32=FOLDERAction33=FOLDERAction34=FOLDERAction35=FOLDERAction36=FOLDERAction37=FOLDERAction38=FOLDERAction39=FOLDERAction4=FOLDERAction40=FOLDERAction41=FOLDERAction42=FOLDERAction43=FOLDERAction44=FOLDERAction45=FOLDERAction46=FOLDERAction47=FOLDERAction48=FOLDERAction49=FOLDERAction5=FOLDERAction50=FOLDERAction51=FOLDERAction52=FOLDERAction53=FOLDERAction54=FOLDERAction55=FOLDERAction56=FOLDERAction57=FOLDERAction58=FOLDERAction59=FOLDERAction6=FOLDERAction60=FOLDERAction61=FOLDERAction7=FOLDERAction8=FOLDERAction9=FOLDER[Actions\Action1]ActionID=STRING|"A_FILE_RENAME"Enabled=INTEGER|-1Name=STRING|"Rename File mars.zip"Params=FOLDER[Actions\Action1\Params]count=STRING|"1"file0=STRING|"D:\Backup Staging Area\mars\mars.zip"mask=STRING|"mars db.zip"subdirs=STRING|"0"[Actions\Action10]ActionID=STRING|"A_INET_SENDMAIL"Enabled=INTEGER|-1Name=STRING|"Send Email"Params=FOLDER[Actions\Action10\Params]attachcount=STRING|"0"auth=STRING|"0"from=STRING|"backup@piainternal.com"host=STRING|"192.168.2.7"html=STRING|"0"msg0=STRING|"Had to delete old mars db.zip file in order to rename mars.zip to mars db.zip."msg2=STRING|"Task will continue."msgcount=STRING|"3"password=STRING|"2591326735249402544926990"port=STRING|"25"subject=STRING|"Warning: Austin - Update MDB Files"to=STRING|"backup@piainternal.com"[Actions\Action11]ActionID=STRING|"A_FILE_RENAME"Enabled=INTEGER|-1Name=STRING|"2nd attempt Rename File mars.zip"Params=FOLDER[Actions\Action11\Params]count=STRING|"1"file0=STRING|"D:\Backup Staging Area\mars\mars.zip"mask=STRING|"mars db.zip"subdirs=STRING|"0"[Actions\Action12]ActionID=STRING|"A_FLOW_IF"Enabled=INTEGER|-1Name=STRING|"If Second rename attempt fails Then Send e-mail Abort Task"Params=FOLDER[Actions\Action12\Params]case=STRING|"0"operator=STRING|"0"type=STRING|"3"value1=STRING|"{IsError}"[Actions\Action13]ActionID=STRING|"A_INET_SENDMAIL"Enabled=INTEGER|-1Name=STRING|"Send Email"Params=FOLDER[Actions\Action13\Params]attachcount=STRING|"0"auth=STRING|"0"from=STRING|"backup@piainternal.com"host=STRING|"192.168.2.7"html=STRING|"0"msg0=STRING|"Second attempt to rename file failed. Zip possibly damaged or incomplete."msg2=STRING|"Task Aborted."msgcount=STRING|"3"password=STRING|"2591326735251962570826217"port=STRING|"25"subject=STRING|"Error: Austin - Update MDB Files"to=STRING|"backup@piainternal.com"[Actions\Action14]ActionID=STRING|"A_TASKS_STOP"Enabled=INTEGER|-1Name=STRING|"Stop Task ""Update Mars Files"""Params=FOLDER[Actions\Action14\Params]taskid=STRING|"1648266511"[Actions\Action15]ActionID=STRING|"A_FLOW_ENDIF"Enabled=INTEGER|-1Name=STRING|"End If"[Actions\Action16]ActionID=STRING|"A_FLOW_ENDIF"Enabled=INTEGER|-1Name=STRING|"End If"[Actions\Action17]ActionID=STRING|"A_ZIP_EXTRACT"Enabled=INTEGER|-1Name=STRING|"Extract Files"Params=FOLDER[Actions\Action17\Params]destdir=STRING|"D:\Backup Staging Area\mars\"filetounzip=STRING|"D:\Backup Staging Area\mars\mars db.zip"overwrite=STRING|"1"password=STRING|"2488924686249422468225199"skipolderfiles=STRING|"0"usefoldernames=STRING|"1"[Actions\Action18]ActionID=STRING|"A_FLOW_IF"Enabled=INTEGER|-1Name=STRING|"If MDB files can not extract Then Send e-mail Abort Task"Params=FOLDER[Actions\Action18\Params]case=STRING|"0"operator=STRING|"0"type=STRING|"3"value1=STRING|"{IsError}"[Actions\Action19]ActionID=STRING|"A_INET_SENDMAIL"Enabled=INTEGER|-1Name=STRING|"Send Email"Params=FOLDER[Actions\Action19\Params]attachcount=STRING|"0"auth=STRING|"0"from=STRING|"backup@piainternal.com"host=STRING|"192.168.2.7"html=STRING|"0"msg0=STRING|"Error occurred while trying to unzip the database files. Zip file possibly damaged or incomplete."msg2=STRING|"Task Aborted."msgcount=STRING|"3"password=STRING|"2591326735254522622526222"port=STRING|"25"subject=STRING|"Error: Austin - Update MDB Files"to=STRING|"backup@piainternal.com"[Actions\Action2]ActionID=STRING|"A_FLOW_IF"Enabled=INTEGER|-1Name=STRING|"IF rename fails THEN go to step ""RF"""Params=FOLDER[Actions\Action2\Params]case=STRING|"0"operator=STRING|"0"type=STRING|"3"value1=STRING|"{IsError}"[Actions\Action20]ActionID=STRING|"A_TASKS_STOP"Enabled=INTEGER|-1Name=STRING|"Abort Task ""Update Mars Files"""Params=FOLDER[Actions\Action20\Params]taskid=STRING|"1648266511"[Actions\Action21]ActionID=STRING|"A_FLOW_ENDIF"Enabled=INTEGER|-1Name=STRING|"End If"[Actions\Action22]ActionID=STRING|"A_FOLDER_REMOVE"Enabled=INTEGER|-1Name=STRING|"Remove Nonempty Folder  (D:\MARS\netdata2_old)"Params=FOLDER[Actions\Action22\Params]deletefolder=STRING|"1"folder=STRING|"D:\MARS\netdata2_old"[Actions\Action23]ActionID=STRING|"A_FOLDER_REMOVE"Enabled=INTEGER|-1Name=STRING|"Remove Nonempty Folder  (D:\MARS\netdata_old)"Params=FOLDER[Actions\Action23\Params]deletefolder=STRING|"1"folder=STRING|"D:\MARS\netdata_old"[Actions\Action24]ActionID=STRING|"A_FOLDER_RENAME"Enabled=INTEGER|-1Name=STRING|"Rename Folder ""D:\MARS\NetData"""Params=FOLDER[Actions\Action24\Params]folder=STRING|"D:\MARS\NetData"newfolder=STRING|"netdata_old"[Actions\Action25]ActionID=STRING|"A_FLOW_IF"Enabled=INTEGER|-1Name=STRING|"If Rename netdata folder fails Then Send e-mail Abort Task"Params=FOLDER[Actions\Action25\Params]case=STRING|"0"operator=STRING|"0"type=STRING|"3"value1=STRING|"{IsError}"[Actions\Action26]ActionID=STRING|"A_INET_SENDMAIL"Enabled=INTEGER|-1Name=STRING|"Send Email"Params=FOLDER[Actions\Action26\Params]attachcount=STRING|"0"auth=STRING|"0"from=STRING|"backup@piainternal.com"host=STRING|"192.168.2.7"html=STRING|"0"msg0=STRING|"Error occurred when trying to renaming netdata folder to netdata_old."msg2=STRING|"Task Will Continue."msgcount=STRING|"3"password=STRING|"2591326735259642468224940"port=STRING|"25"subject=STRING|"Warning: Austin - Update MDB Files"to=STRING|"backup@piainternal.com"[Actions\Action27]ActionID=STRING|"A_FLOW_ENDIF"Enabled=INTEGER|-1Name=STRING|"End If"[Actions\Action28]ActionID=STRING|"A_FOLDER_RENAME"Enabled=INTEGER|-1Name=STRING|"Rename Folder ""D:\MARS\NetData2"""Params=FOLDER[Actions\Action28\Params]folder=STRING|"D:\MARS\NetData2"newfolder=STRING|"netdata2_old"[Actions\Action29]ActionID=STRING|"A_FLOW_IF"Enabled=INTEGER|-1Name=STRING|"If Rename netdata2 fails Then Rename netdata_old back to netdata, send e-mail abort task"Params=FOLDER[Actions\Action29\Params]case=STRING|"0"operator=STRING|"0"type=STRING|"3"value1=STRING|"{IsError}"[Actions\Action3]ActionID=STRING|"A_FLOW_IF"Enabled=INTEGER|-1Name=STRING|"""RF"" IF mars db.zip exists THEN do ""DF"""Params=FOLDER[Actions\Action3\Params]case=STRING|"0"operator=STRING|"0"type=STRING|"3"value1=STRING|"{FileExists(D:\Backup Staging Area\mars\mars db.zip)}"[Actions\Action30]ActionID=STRING|"A_INET_SENDMAIL"Enabled=INTEGER|-1Name=STRING|"Send Email"Params=FOLDER[Actions\Action30\Params]attachcount=STRING|"0"auth=STRING|"0"from=STRING|"backup@piainternal.com"host=STRING|"192.168.2.5"html=STRING|"0"msg0=STRING|"Error occurred when trying to renam netdata2 folder to netdata2_old."msg1=STRING|"netdata_old renamed back to netdata."msg3=STRING|"Task Will Continue."msgcount=STRING|"4"password=STRING|"2591326735262202519324945"port=STRING|"25"subject=STRING|"Warning: Austin - Update MDB Files"to=STRING|"backup@piainternal.com"[Actions\Action31]ActionID=STRING|"A_FLOW_ENDIF"Enabled=INTEGER|-1Name=STRING|"End If"[Actions\Action32]ActionID=STRING|"A_FLOW_IF"Enabled=INTEGER|-1Name=STRING|"If Then"Params=FOLDER[Actions\Action32\Params]case=STRING|"0"operator=STRING|"0"type=STRING|"3"value1=STRING|"{FolderExists({d:\mars\netdata})}"[Actions\Action33]ActionID=STRING|"A_INET_SENDMAIL"Enabled=INTEGER|-1Name=STRING|"Send Email"Params=FOLDER[Actions\Action33\Params]attachcount=STRING|"0"auth=STRING|"0"from=STRING|"backup@piainternal.com"host=STRING|"192.168.2.7"html=STRING|"0"msg0=STRING|"Enter message body"msgcount=STRING|"1"password=STRING|"2591326735262222597026736"port=STRING|"25"subject=STRING|"Error: Austin - Task Aborted Netdata exists and couldn't be renamed"to=STRING|"backup@piainternal.com"[Actions\Action34]ActionID=STRING|"A_TASKS_STOP"Enabled=INTEGER|-1Name=STRING|"Stop Task ""Update Mars Files"""Params=FOLDER[Actions\Action34\Params]taskid=STRING|"1648266511"[Actions\Action35]ActionID=STRING|"A_FLOW_ENDIF"Enabled=INTEGER|-1Name=STRING|"End If"[Actions\Action36]ActionID=STRING|"A_FLOW_IF"Enabled=INTEGER|-1Name=STRING|"If Then"Params=FOLDER[Actions\Action36\Params]case=STRING|"0"operator=STRING|"0"type=STRING|"3"value1=STRING|"{FolderExists({d:\mars\netdata2})}"[Actions\Action37]ActionID=STRING|"A_INET_SENDMAIL"Enabled=INTEGER|-1Name=STRING|"Send Email"Params=FOLDER[Actions\Action37\Params]attachcount=STRING|"0"auth=STRING|"0"from=STRING|"backup@piainternal.com"host=STRING|"192.168.2.7"html=STRING|"0"msg0=STRING|"Enter message body"msgcount=STRING|"1"password=STRING|"2591326735264782673826990"port=STRING|"25"subject=STRING|"Error: Austin - Task Aborted Netdata2 exists and couldn't be renamed"to=STRING|"backup@piainternal.com"[Actions\Action38]ActionID=STRING|"A_TASKS_STOP"Enabled=INTEGER|-1Name=STRING|"Stop Task ""Update Mars Files"""Params=FOLDER[Actions\Action38\Params]taskid=STRING|"1648266511"[Actions\Action39]ActionID=STRING|"A_FLOW_ENDIF"Enabled=INTEGER|-1Name=STRING|"End If"[Actions\Action4]ActionID=STRING|"A_FILE_DELETE"Enabled=INTEGER|-1Name=STRING|"""DF"" Delete File"Params=FOLDER[Actions\Action4\Params]Count=STRING|"1"deletedirs=STRING|"0"file0=STRING|"D:\Backup Staging Area\mars\mars db.zip"subdir=STRING|"0"ToRecycleBin=STRING|"1"[Actions\Action40]ActionID=STRING|"A_FOLDER_CREATE"Enabled=INTEGER|-1Name=STRING|"Create Folder (D:\MARS\NetData)"Params=FOLDER[Actions\Action40\Params]newfolder=STRING|"D:\MARS\NetData"[Actions\Action41]ActionID=STRING|"A_FOLDER_CREATE"Enabled=INTEGER|-1Name=STRING|"Create Folder (D:\MARS\NetData2)"Params=FOLDER[Actions\Action41\Params]newfolder=STRING|"D:\MARS\NetData2"[Actions\Action42]ActionID=STRING|"A_FILE_COPY"Enabled=INTEGER|-1Name=STRING|"Move File"Params=FOLDER[Actions\Action42\Params]destdir=STRING|"D:\MARS\NetData"f_count=STRING|"1"file0=STRING|"D:\Backup Staging Area\mars\ndconfig\dbconfig.ipx"ifexists=STRING|"1"move=STRING|"0"subdir=STRING|"0"[Actions\Action43]ActionID=STRING|"A_FLOW_IF"Enabled=INTEGER|-1Name=STRING|"If Then"Params=FOLDER[Actions\Action43\Params]case=STRING|"0"operator=STRING|"0"type=STRING|"3"value1=STRING|"{IsError}"[Actions\Action44]ActionID=STRING|"A_FOLDER_RENAME"Enabled=INTEGER|-1Name=STRING|"Rename Folder ""D:\MARS\netdata_old"""Params=FOLDER[Actions\Action44\Params]folder=STRING|"D:\MARS\netdata_old"newfolder=STRING|"netdata"[Actions\Action45]ActionID=STRING|"A_FOLDER_RENAME"Enabled=INTEGER|-1Name=STRING|"Rename Folder ""D:\MARS\netdata2_old"""Params=FOLDER[Actions\Action45\Params]folder=STRING|"D:\MARS\netdata2_old"newfolder=STRING|"netdata2"[Actions\Action46]ActionID=STRING|"A_INET_SENDMAIL"Enabled=INTEGER|-1Name=STRING|"Send Email"Params=FOLDER[Actions\Action46\Params]attachcount=STRING|"0"auth=STRING|"0"from=STRING|"backup@piainternal.com"host=STRING|"192.168.2.5"html=STRING|"0"msg0=STRING|"Error Coping dbconfig.ipx"msgcount=STRING|"1"password=STRING|"2591326735267342648126226"port=STRING|"25"subject=STRING|"RT Mars DB Update Process Error"to=STRING|"backup@piainternal.com"[Actions\Action47]ActionID=STRING|"A_TASKS_STOP"Enabled=INTEGER|-1Name=STRING|"Abort Task ""Update Mars Files"""Params=FOLDER[Actions\Action47\Params]taskid=STRING|"1648266511"[Actions\Action48]ActionID=STRING|"A_FLOW_ENDIF"Enabled=INTEGER|-1Name=STRING|"End If"[Actions\Action49]ActionID=STRING|"A_FILE_COPY"Enabled=INTEGER|-1Name=STRING|"Copy/Move File"Params=FOLDER[Actions\Action49\Params]destdir=STRING|"D:\MARS\NetData"f_count=STRING|"2"file0=STRING|"D:\Backup Staging Area\mars\MARS\temp_nd\marswsql.db"file1=STRING|"D:\Backup Staging Area\mars\MARS\temp_nd\marswsql.log"ifexists=STRING|"0"move=STRING|"1"subdir=STRING|"0"[Actions\Action5]ActionID=STRING|"A_FLOW_IF"Enabled=INTEGER|-1Name=STRING|"If delete mars db.zip fails then Send e-mail Abort task"Params=FOLDER[Actions\Action5\Params]case=STRING|"0"operator=STRING|"0"type=STRING|"3"value1=STRING|"{IsError}"[Actions\Action50]ActionID=STRING|"A_FLOW_IF"Enabled=INTEGER|-1Name=STRING|"If Then"Params=FOLDER[Actions\Action50\Params]case=STRING|"0"operator=STRING|"0"type=STRING|"3"value1=STRING|"{IsError}"[Actions\Action51]ActionID=STRING|"A_FILE_COPY"Enabled=INTEGER|-1Name=STRING|"Copy/Move File"Params=FOLDER[Actions\Action51\Params]destdir=STRING|"D:\MARS\NetData2"f_count=STRING|"2"file0=STRING|"D:\MARS\netdata2_old\marswsql.db"file1=STRING|"D:\MARS\netdata2_old\marswsql.log"ifexists=STRING|"1"move=STRING|"1"subdir=STRING|"0"[Actions\Action52]ActionID=STRING|"A_FILE_COPY"Enabled=INTEGER|-1Name=STRING|"Copy/Move File"Params=FOLDER[Actions\Action52\Params]destdir=STRING|"D:\MARS\NetData"f_count=STRING|"3"file0=STRING|"D:\MARS\netdata_old\marswsql.db"file1=STRING|"D:\MARS\netdata_old\marswsql.log"file2=STRING|"D:\MARS\NetData_old\dbconfig.ipx"ifexists=STRING|"1"move=STRING|"1"subdir=STRING|"0"[Actions\Action53]ActionID=STRING|"A_INET_SENDMAIL"Enabled=INTEGER|-1Name=STRING|"Send Email"Params=FOLDER[Actions\Action53\Params]attachcount=STRING|"0"auth=STRING|"0"from=STRING|"backup@piainternal.com"host=STRING|"192.168.2.5"html=STRING|"0"msg0=STRING|"Error copying new mars DB files"msgcount=STRING|"1"password=STRING|"2591326735246872493724944"port=STRING|"25"subject=STRING|"RT Mars  DB Update Process"to=STRING|"backup@piainternal.com"[Actions\Action54]ActionID=STRING|"A_TASKS_STOP"Enabled=INTEGER|-1Name=STRING|"Abort Task ""Update Mars Files"""Params=FOLDER[Actions\Action54\Params]taskid=STRING|"1648266511"[Actions\Action55]ActionID=STRING|"A_FLOW_ENDIF"Enabled=INTEGER|-1Name=STRING|"End If"[Actions\Action56]ActionID=STRING|"A_FILE_COPY"Enabled=INTEGER|-1Name=STRING|"Copy/Move File"Params=FOLDER[Actions\Action56\Params]destdir=STRING|"D:\MARS\NetData2"f_count=STRING|"2"file0=STRING|"D:\Backup Staging Area\mars\MARS\temp_nd2\marswsql.db"file1=STRING|"D:\Backup Staging Area\mars\MARS\temp_nd2\marswsql.log"ifexists=STRING|"1"move=STRING|"1"subdir=STRING|"0"[Actions\Action57]ActionID=STRING|"A_FILE_COPY"Enabled=INTEGER|-1Name=STRING|"Copy/Move File"Params=FOLDER[Actions\Action57\Params]destdir=STRING|"D:\Backup Staging Area\mars\ndconfig"f_count=STRING|"1"file0=STRING|"D:\Backup Staging Area\mars\backup\backup_log.txt"ifexists=STRING|"0"move=STRING|"1"subdir=STRING|"0"[Actions\Action58]ActionID=STRING|"A_FOLDER_REMOVE"Enabled=INTEGER|-1Name=STRING|"Remove Empty Folder (D:\Backup Staging Area\mars\backup)"Params=FOLDER[Actions\Action58\Params]deletefolder=STRING|"0"folder=STRING|"D:\Backup Staging Area\mars\backup"[Actions\Action59]ActionID=STRING|"A_FOLDER_REMOVE"Enabled=INTEGER|-1Name=STRING|"Remove Empty Folder (D:\Backup Staging Area\mars\MARS)"Params=FOLDER[Actions\Action59\Params]deletefolder=STRING|"0"folder=STRING|"D:\Backup Staging Area\mars\MARS"[Actions\Action6]ActionID=STRING|"A_INET_SENDMAIL"Enabled=INTEGER|-1Name=STRING|"Send Email"Params=FOLDER[Actions\Action6\Params]attachcount=STRING|"0"auth=STRING|"0"from=STRING|"backup@piainternal.com"host=STRING|"192.168.2.7"html=STRING|"0"msg0=STRING|"Delete failed, Database files not updated."msg2=STRING|"Could not delete old mars db.zip file."msg4=STRING|"Task aborted."msgcount=STRING|"5"password=STRING|"2591326735249402519725967"port=STRING|"25"subject=STRING|"Error: Austin - Update MDB Files"to=STRING|"backup@piainternal.com"[Actions\Action60]ActionID=STRING|"A_FILE_DELETE"Enabled=INTEGER|-1Name=STRING|"Delete File"Params=FOLDER[Actions\Action60\Params]Count=STRING|"1"deletedirs=STRING|"0"file0=STRING|"D:\Backup Staging Area\mars\mars db.zip"subdir=STRING|"0"ToRecycleBin=STRING|"1"[Actions\Action61]ActionID=STRING|"A_INET_SENDMAIL"Enabled=INTEGER|-1Name=STRING|"Send Email"Params=FOLDER[Actions\Action61\Params]attachcount=STRING|"0"auth=STRING|"0"from=STRING|"backup@piainternal.com"host=STRING|"192.168.2.7"html=STRING|"0"msg0=STRING|"Task completed successfuly."msgcount=STRING|"1"password=STRING|"2591326735246872648125449"port=STRING|"25"subject=STRING|"Austin MDB Update completed successfuly"to=STRING|"backup@piainternal.com"[Actions\Action7]ActionID=STRING|"A_TASKS_STOP"Enabled=INTEGER|-1Name=STRING|"Abort Task ""Update Mars Files"""Params=FOLDER[Actions\Action7\Params]taskid=STRING|"1648266511"[Actions\Action8]ActionID=STRING|"A_FLOW_ENDIF"Enabled=INTEGER|-1Name=STRING|"End If"[Actions\Action9]ActionID=STRING|"A_FLOW_ENDIF"Enabled=INTEGER|-1Name=STRING|"End If"[Events]Event1=FOLDER[Events\Event1]Enabled=INTEGER|-1EventID=STRING|"E_GENERAL_SHEDULER"Params=FOLDER[Events\Event1\Params]id=STRING|"LFM01HV8"periodicity=STRING|"0"startdate=STRING|"4294312528"time0=STRING|"900000"time1=STRING|"54900000"time2=STRING|"65700000"time3=STRING|"76500000"timecount=STRING|"4"
Thank you very much for your suggestions. We'll remove these troubles necessarily in next release.
pathfinder
Awsome! Thank You
