JSON array processing
aseethar
Post by aseethar »
I am trying to process a json array in a loop of a task
I have got the correct number of array elements and stuggling to retrieve each username
My json array looks like this - how do I get to the username so that I can set the value of a variable as I loop?
"usersToEndSessions": [
"Row ID": "fc5cb3f0-916d-11ed-a5df-01647197df94",
"Created": "2023-01-11T05:08:28.979Z",
"Updated": "2023-01-11T05:51:04.345Z",
"username": "john.steven"
"Row ID": "71b9bc90-915c-11ed-a4c8-ee77646f8fe3",
"Created": "2023-01-11T03:02:54.941Z",
"Updated": "2023-01-11T05:51:04.353Z",
"username": "sam.smith"
What I have tried so far:
Works: Set a variable local@usersToEndSessionsValue to {json:local@RESTRESPONSE.usersToEndSessions}
Does not work: Log Message {json:local@usersToEndSessionsValue[1].username}
I'd expect it to log a username but instead simply prints out the whole string
Could not find any robotask doc on json array processing in a loop - thanks for your help
Re: JSON array processing
Why JSON? I think you need save your JSON to simple variable: local@RESTRESPONSE
Next you can process the value as JSON: {json:local@RESTRESPONSE.usersToEndSessionsValue[1].username}
Look at my example below. It works.
CatID=INTEGER|693415217
ExternalName=STRING|"Task29"
ID=INTEGER|-620743232
Name=STRING|"Json array in the loop"
Name=STRING|"Set JSON to variable ""local@RESTRESPONSE"""
linecount=STRING|"16"
varname=STRING|"local@RESTRESPONSE"
varvalue=STRING|"{"
varvalue00000001=STRING|"""usersToEndSessions"": ["
varvalue00000002=STRING|"{"
varvalue00000003=STRING|"""Row ID"": ""fc5cb3f0-916d-11ed-a5df-01647197df94"","
varvalue00000004=STRING|"""Created"": ""2023-01-11T05:08:28.979Z"","
varvalue00000005=STRING|"""Updated"": ""2023-01-11T05:51:04.345Z"","
varvalue00000006=STRING|"""username"": ""john.steven"""
varvalue00000007=STRING|"},"
varvalue00000008=STRING|"{"
varvalue00000009=STRING|"""Row ID"": ""71b9bc90-915c-11ed-a4c8-ee77646f8fe3"","
varvalue0000000A=STRING|"""Created"": ""2023-01-11T03:02:54.941Z"","
varvalue0000000B=STRING|"""Updated"": ""2023-01-11T05:51:04.353Z"","
varvalue0000000C=STRING|"""username"": ""sam.smith"""
varvalue0000000D=STRING|"}"
varvalue0000000E=STRING|"]"
varvalue0000000F=STRING|"}"
Enabled=INTEGER|0
Name=STRING|"Show Text"
autoclose=STRING|"0"
fromfile=STRING|"1"
line00000000=STRING|"{RestResponse}"
timeout=STRING|"10"
ActionID=STRING|"A_VARCOUNTELEMENTS"
Name=STRING|"Count array elements (as JSON array)"
mode=STRING|"1"
source=STRING|"{json:RestResponse.usersToEndSessions}"
variable=STRING|"num"
message=STRING|"{num}"
Name=STRING|"Simple Loop"
begin=STRING|"0"
end=STRING|"{Subtract({num},1)}"
step=STRING|"1"
variable=STRING|"ITEM"
message=STRING|"{json:RestResponse.usersToEndSessions[{item}].username}"
aseethar
Post by aseethar »
Oleg, your solution was exactly what I was looking for. Using the new feature of Rest Client/Invoke Web Service and COUNTARRAY with JSON. Thanks!
