Data Execution Prevention (DEP)
pathfinder
Post by pathfinder »
This comes up everytime I log in and I can not get it to go away.
Also when I try to start the robotask service it gives me this error in the event viewer and will not open.
Faulting application RoboTask.exe, version 2.4.0.28, faulting module unknown, version 0.0.0.0, fault address 0x01d722a1.
I am running windows 2003 std with all the latest service packs and updates.
pathfinder
I just figured it out. You have to put a check by robotask in the DEP settings window. Then restart windows.
Yes, it is correct solution.
When you want to use RoboTask as service in Windows 2003 server SP1 you must to tune DEP
