Check for filenames with spaces (File Monitor)
Hey Oleg,
I want to trigger a task with File Monitor, but only when the filenames contain (a) space(s). They should be replaced in the task itself. I've tried a with * *.* and also this didn't work:
In the example above, it triggers on anything. What can you adivse me?
Re: Check for filenames with spaces (File Monitor)
You must use the mask in quotes, like this
You can specify several search masks as comma-separated string. Standard comma-separated string means that if any element contains spaces, it must be enclosed in quotation marks.
Also look at my simple example. It monitors files with spaces only
CatID=INTEGER|265541000
ExternalName=STRING|"Task14"
ID=INTEGER|934778895
Name=STRING|"Monitor files with spaces"
msg1=STRING|"Hey, awake! New files"
msgcount=STRING|"2"
Name=STRING|"File Monitor"
UniqueID=INTEGER|1856915451
chg=STRING|"1"
chga=STRING|"1"
chgsl=STRING|"1"
chgsm=STRING|"1"
chgtl=STRING|"1"
chgtm=STRING|"1"
del=STRING|"1"
folder1=STRING|"D:\temp\Folder with - space"
foldercount=STRING|"1"
incmask=STRING|"""* *.*"""
interval=STRING|"3"
listmode=STRING|"1"
mon_files=STRING|"1"
mon_folders=STRING|"0"
new=STRING|"1"
notsavestatus=STRING|"0"
pass=STRING|"0"
passmode=STRING|"1"
required=STRING|"0"
saveresults=STRING|"0"
subfolders1=STRING|"0"
Great, that did the trick! Many thanks!
