How to wait for a pop-up message?
arold_ite
Post by arold_ite »
Hi, I have "move-to" and "click" actions set-up for a specific message box.  But, when the actions execute, the message box doesn't YET exist.
The application that I'm starting goes away and does some processing and after an unknown amount of time, it comes back with a message box, to which I should press OK.
I never how long it will take for this message box to appear.  So, how can I tell RoboTask to WAIT for this message box to appear?
Thanks
Arold
Simplest solution:
place some pause before mouse movements and keystrokes (see Pause action).
Another way:
use the following algorithm
simple loop from 1 to 1000 //for example
   if {IsWindowVisible(Caption Of Your Dialog)} then
      break
   else
      pause 100 ms
   end if
end loop
do keystrokes and mouse actions
this block waits until your window will appear.
