Problem extracting URL
Micha
Post by Micha »
Problem: Having URL, getting textresponse from this, extracting Picture-URL an save it to disc.
I have an URL e.g. (allready with Robotask-DateTimeFormat
https://charts.ecmwf.int/opencharts-api/v1/products/extended-anomaly-t/?format=png&base_time={DateTimeToFormat({DateIncDays(-1)},yyyy-mm-dd)}T00%3A00%3A00Z&step=168&valid_time={DateTimeToFormat({DateIncDays(+48)},yyyy-mm-dd)}T00%3A00%3A00Z&projection=opencharts_europe
This results in a json-text
{"meta":{"terms-and-conditions":{"href":"https://apps.ecmwf.int/datasets/licences/general/"},"license":"CC-BY-4.0","copyright":"2021 European Centre for Medium-Range Weather Forecasts"},"data":{"link":{"href":"https://charts.ecmwf.int/content/20221022074250-922b4e7c10c3ff63220e3878ac7c5c7057c62189.png","type":"image/png"},"attributes":{"description":"Base time: Mon 17 Oct 2022 Valid time: Mon 17 Oct 2022 - Mon 24 Oct 2022 (+168h) Area : Europe","name":"extended-anomaly-t","title":"Surface temperature: Weekly mean anomalies"},"type":"graphical_product"},"tracker":"tracker-c48168a439b74fd4bf38411751139e80","uid":""}
Now I have to extract the url oft he png-image (here e.g. https://charts.ecmwf.int/content/202210 ... c62189.png) and save it with new filename to disc.
How to solve it with robotask?
Re: Problem extracting URL
Suppose you save the response in SourceData variable
use the expression
{json:SourceData.data.link.href}
to extract PNG link
Also look an my small example. Save the text of the task to a file and use menu Task->Import to import the task into RoboTask.
Then you can look at the task in task editor
ExternalName=STRING|"Task1502"
ID=INTEGER|-730918599
Name=STRING|"extract PNG URL"
Name=STRING|"Set variable ""SourceData"" with value ""{""meta"":{""terms-and-conditions"":{""href"":""https://apps.ecmwf.int/datasets/licences/general/""},""license"":""CC-BY-4.0"",""copyright"":""2021 European Centre for Medium-..."""
varname=STRING|"SourceData"
varvalue=STRING|"{""meta"":{""terms-and-conditions"":{""href"":""https://apps.ecmwf.int/datasets/licences/general/""},""license"":""CC-BY-4.0"",""copyright"":""2021 European Centre for Medium-Range Weather Forecasts""},""data"":{""link"":{""href"":""https://charts.ecmwf.int/content/20221022074250-922b4e7c10c3ff63220e3878ac7c5c7057c62189.png"",""type"":""image/png""},""attributes"":{""description"":""Base time: Mon 17 Oct 2022 Valid time: Mon 17 Oct 2022 - Mon 24 Oct 2022 (+168h) Area : Europe"",""name"":""extended-anomaly-t"",""title"":""Surface temperature: Weekly mean anomalies""},""type"":""graphical_product""},""tracker"":""tracker-c48168a439b74fd4bf38411751139e80"",""uid"":""""}"
Name=STRING|"Show ""{json:SourceData.data.link.href}"""
msg0=STRING|"{json:SourceData.data.link.href}"
>>Read more about JSON prefix here<<
To save PNG use Download Files action
Micha
Post by Micha »
Thank you Oleg :D
I still had to make it variable, but now it's working. It's a bit tricky, but it works now.
Micha
Post by Micha »
I have another question... my script is working so far, but i want to do it more elegant ;)
At the moment i give Robotask an URL like
https://charts.ecmwf.int/opencharts-api/v1/products/extended-anomaly-t/?format=png&base_time=2022-10-24T00%3A00%3A00Z&step=168&valid_time=2022-12-05T00%3A00%3A00Z&projection=opencharts_europe
and save the returned code (json) to an external file on disk.
Then i read this external file and store the json to a variable. (as you described)
Then i download the picture (as you described).
Works :D
Is it possible to store the returned json-code directly to a variable? (no tmpdir and no files), only a variable.
I want to do the query without the intermediate step with the external files. (because i have not only one url... alltogether i have 8 urls, but there will be more).
Micha
Post by Micha »
At the moment the task looks like this
CatID=INTEGER|494636794
ExternalName=STRING|"Task112"
ID=INTEGER|-1870147743
LocalVariables=STRING|"TT168URL="
Name=STRING|"NEW EZMW Download Dienstag"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
Action21=FOLDER
Action22=FOLDER
Action23=FOLDER
Action24=FOLDER
Action25=FOLDER
Action26=FOLDER
Action27=FOLDER
Action28=FOLDER
Enabled=INTEGER|0
Name=STRING|"//-------- Temperatur --------"
comment=STRING|"-------- Temperatur --------"
ActionID=STRING|"A_INET_DOWNLOAD"
Name=STRING|"Download 504 and save in ""Y:\json"""
action=STRING|"1"
authorization=STRING|"0"
file0=STRING|"{json:SourceData504tt.data.link.href}"
password=STRING|"1293912482140201478313507"
proxykind=STRING|"0"
saveas=STRING|"1"
saveasname=STRING|"ezmwf_eur_ttt_anom_{Year}_wk{WeekOfTheYear({Date})}_mon_fc3.png"
savedir=STRING|"Y:\json"
useproxy=STRING|"0"
Name=STRING|"672 TT -------- Download files and save in ""Y:\json"" --------"
action=STRING|"1"
file0=STRING|"https://charts.ecmwf.int/opencharts-api/v1/products/extended-anomaly-2t/?format=png&base_time={DateTimeToFormat({DateIncDays(-1)},yyyy-mm-dd)}T00%3A00%3A00Z&step=672&valid_time={DateTimeToFormat({DateIncDays(+48)},yyyy-mm-dd)}T00%3A00%3A00Z&projection=opencharts_europe"
password=STRING|"1345112476135021248112993"
saveas=STRING|"1"
saveasname=STRING|"ecmwf_tt_672.json"
useproxy=STRING|"0"
ActionID=STRING|"A_READ_TXTFILE"
Name=STRING|"Read ""Y:\json\ecmwf_tt_672.json"" (65001)"
[Actions\Action12\Params]
codepage=STRING|"65001"
filename=STRING|"Y:\json\ecmwf_tt_672.json"
replacenull=STRING|"0"
varname=STRING|"SourceData672tt"
Name=STRING|"Download 672 and save in ""Y:\json"""
[Actions\Action13\Params]
action=STRING|"1"
file0=STRING|"{json:SourceData672tt.data.link.href}"
password=STRING|"1293912738142671324514784"
saveas=STRING|"1"
saveasname=STRING|"ezmwf_eur_ttt_anom_{Year}_wk{WeekOfTheYear({Date})}_mon_fc4.png"
useproxy=STRING|"0"
[Actions\Action14]
Enabled=INTEGER|0
Name=STRING|"//-------- Niederschlag --------"
[Actions\Action14\Params]
comment=STRING|"-------- Niederschlag --------"
[Actions\Action15]
Name=STRING|"168 RR Download files and save in ""Y:\json"""
[Actions\Action15\Params]
action=STRING|"1"
file0=STRING|"https://charts.ecmwf.int/opencharts-api/v1/products/extended-anomaly-tp/?format=png&base_time={DateTimeToFormat({DateIncDays(-1)},yyyy-mm-dd)}T00%3A00%3A00Z&step=168&valid_time={DateTimeToFormat({DateIncDays(+48)},yyyy-mm-dd)}T00%3A00%3A00Z&projection=opencharts_europe"
password=STRING|"1293912476140131248314015"
saveas=STRING|"1"
saveasname=STRING|"ecmwf_rr_168.json"
useproxy=STRING|"0"
[Actions\Action16]
Name=STRING|"Read ""Y:\json\ecmwf_rr_168.json"" (65001)"
[Actions\Action16\Params]
filename=STRING|"Y:\json\ecmwf_rr_168.json"
varname=STRING|"SourceData168rr"
[Actions\Action17]
Name=STRING|"Download 168 and save in ""Y:\json"""
[Actions\Action17\Params]
action=STRING|"1"
file0=STRING|"{json:SourceData168rr.data.link.href}"
password=STRING|"1293912738129951375613756"
saveas=STRING|"1"
saveasname=STRING|"ezmwf_eur_rrr_anom_{Year}_wk{WeekOfTheYear({Date})}_mon_fc1.png"
useproxy=STRING|"0"
[Actions\Action18]
Name=STRING|"336 RR Download files and save in ""Y:\json"""
[Actions\Action18\Params]
action=STRING|"1"
file0=STRING|"https://charts.ecmwf.int/opencharts-api/v1/products/extended-anomaly-tp/?format=png&base_time={DateTimeToFormat({DateIncDays(-1)},yyyy-mm-dd)}T00%3A00%3A00Z&step=336&valid_time={DateTimeToFormat({DateIncDays(+48)},yyyy-mm-dd)}T00%3A00%3A00Z&projection=opencharts_europe"
password=STRING|"1293912476127341298813761"
saveas=STRING|"1"
saveasname=STRING|"ecmwf_rr_336.json"
useproxy=STRING|"0"
[Actions\Action19]
Name=STRING|"Read ""Y:\json\ecmwf_rr_336.json"" (65001)"
[Actions\Action19\Params]
filename=STRING|"Y:\json\ecmwf_rr_336.json"
varname=STRING|"SourceData336rr"
Name=STRING|"168 TT -------- Download files and save in ""Y:\json"" --------"
action=STRING|"1"
file0=STRING|"https://charts.ecmwf.int/opencharts-api/v1/products/extended-anomaly-2t/?format=png&base_time={DateTimeToFormat({DateIncDays(-1)},yyyy-mm-dd)}T00%3A00%3A00Z&step=168&valid_time={DateTimeToFormat({DateIncDays(+48)},yyyy-mm-dd)}T00%3A00%3A00Z&projection=opencharts_europe"
password=STRING|"1345112476127341452913247"
saveas=STRING|"1"
saveasname=STRING|"ecmwf_tt_168.json"
useproxy=STRING|"0"
[Actions\Action20]
Name=STRING|"Download 336 and save in ""Y:\json"""
[Actions\Action20\Params]
action=STRING|"1"
file0=STRING|"{json:SourceData336rr.data.link.href}"
password=STRING|"1293912738147871478213248"
saveas=STRING|"1"
saveasname=STRING|"ezmwf_eur_rrr_anom_{Year}_wk{WeekOfTheYear({Date})}_mon_fc2.png"
useproxy=STRING|"0"
[Actions\Action21]
Name=STRING|"504 RR Download files and save in ""Y:\json"""
[Actions\Action21\Params]
action=STRING|"1"
file0=STRING|"https://charts.ecmwf.int/opencharts-api/v1/products/extended-anomaly-tp/?format=png&base_time={DateTimeToFormat({DateIncDays(-1)},yyyy-mm-dd)}T00%3A00%3A00Z&step=504&valid_time={DateTimeToFormat({DateIncDays(+48)},yyyy-mm-dd)}T00%3A00%3A00Z&projection=opencharts_europe"
password=STRING|"1293912476135021375814530"
saveas=STRING|"1"
saveasname=STRING|"ecmwf_rr_504.json"
useproxy=STRING|"0"
[Actions\Action22]
Name=STRING|"Read ""Y:\json\ecmwf_rr_504.json"" (65001)"
[Actions\Action22\Params]
filename=STRING|"Y:\json\ecmwf_rr_504.json"
varname=STRING|"SourceData504rr"
[Actions\Action23]
[Actions\Action23\Params]
action=STRING|"1"
file0=STRING|"{json:SourceData504rr.data.link.href}"
password=STRING|"1293912738135081324512988"
saveas=STRING|"1"
saveasname=STRING|"ezmwf_eur_rrr_anom_{Year}_wk{WeekOfTheYear({Date})}_mon_fc3.png"
useproxy=STRING|"0"
[Actions\Action24]
Name=STRING|"672 RR Download files and save in ""Y:\json"""
[Actions\Action24\Params]
action=STRING|"1"
file0=STRING|"https://charts.ecmwf.int/opencharts-api/v1/products/extended-anomaly-tp/?format=png&base_time={DateTimeToFormat({DateIncDays(-1)},yyyy-mm-dd)}T00%3A00%3A00Z&step=672&valid_time={DateTimeToFormat({DateIncDays(+48)},yyyy-mm-dd)}T00%3A00%3A00Z&projection=opencharts_europe"
password=STRING|"1293914012145321401514275"
saveas=STRING|"1"
saveasname=STRING|"ecmwf_rr_672.json"
useproxy=STRING|"0"
[Actions\Action25]
Name=STRING|"Read ""Y:\json\ecmwf_rr_672.json"" (65001)"
[Actions\Action25\Params]
filename=STRING|"Y:\json\ecmwf_rr_672.json"
varname=STRING|"SourceData672rr"
[Actions\Action26]
[Actions\Action26\Params]
action=STRING|"1"
file0=STRING|"{json:SourceData672rr.data.link.href}"
password=STRING|"1293912738147881427013502"
saveas=STRING|"1"
saveasname=STRING|"ezmwf_eur_rrr_anom_{Year}_wk{WeekOfTheYear({Date})}_mon_fc4.png"
useproxy=STRING|"0"
[Actions\Action27]
Enabled=INTEGER|0
Name=STRING|"//-------- Verteilung --------"
[Actions\Action27\Params]
comment=STRING|"-------- Verteilung --------"
[Actions\Action28]
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy Files nach /ezmwf"
[Actions\Action28\Params]
destdir=STRING|"Y:\ezmwf"
f_count=STRING|"1"
file0=STRING|"Y:\json\ezmwf_*.png"
hidden=STRING|"0"
ifexists=STRING|"0"
move=STRING|"0"
rename=STRING|"0"
renamemask=STRING|"*.*.new"
subdir=STRING|"0"
system=STRING|"0"
Name=STRING|"Read ""Y:\json\ecmwf_tt_168.json"" (65001)"
filename=STRING|"Y:\json\ecmwf_tt_168.json"
varname=STRING|"SourceData168tt"
action=STRING|"1"
file0=STRING|"{json:SourceData168tt.data.link.href}"
password=STRING|"1293913506145251375512475"
saveas=STRING|"1"
saveasname=STRING|"ezmwf_eur_ttt_anom_{Year}_wk{WeekOfTheYear({Date})}_mon_fc1.png"
useproxy=STRING|"0"
Name=STRING|"336 TT -------- Download files and save in ""Y:\json"" --------"
action=STRING|"1"
file0=STRING|"https://charts.ecmwf.int/opencharts-api/v1/products/extended-anomaly-2t/?format=png&base_time={DateTimeToFormat({DateIncDays(-1)},yyyy-mm-dd)}T00%3A00%3A00Z&step=336&valid_time={DateTimeToFormat({DateIncDays(+48)},yyyy-mm-dd)}T00%3A00%3A00Z&projection=opencharts_europe"
password=STRING|"1345112476129901350514011"
saveas=STRING|"1"
saveasname=STRING|"ecmwf_tt_336.json"
useproxy=STRING|"0"
Name=STRING|"Read ""Y:\json\ecmwf_tt_336.json"" (65001)"
filename=STRING|"Y:\json\ecmwf_tt_336.json"
varname=STRING|"SourceData336tt"
action=STRING|"1"
file0=STRING|"{json:SourceData336tt.data.link.href}"
password=STRING|"1293912482124831427513502"
saveas=STRING|"1"
saveasname=STRING|"ezmwf_eur_ttt_anom_{Year}_wk{WeekOfTheYear({Date})}_mon_fc2.png"
useproxy=STRING|"0"
Name=STRING|"504 TT -------- Download files and save in ""Y:\json"" --------"
action=STRING|"1"
file0=STRING|"https://charts.ecmwf.int/opencharts-api/v1/products/extended-anomaly-2t/?format=png&base_time={DateTimeToFormat({DateIncDays(-1)},yyyy-mm-dd)}T00%3A00%3A00Z&step=504&valid_time={DateTimeToFormat({DateIncDays(+48)},yyyy-mm-dd)}T00%3A00%3A00Z&projection=opencharts_europe"
password=STRING|"1345112476132461453012484"
saveas=STRING|"1"
saveasname=STRING|"ecmwf_tt_504.json"
useproxy=STRING|"0"
Name=STRING|"Read ""Y:\json\ecmwf_tt_504.json"" (65001)"
filename=STRING|"Y:\json\ecmwf_tt_504.json"
varname=STRING|"SourceData504tt"
Name=STRING|"Scheduler(25.10.2022 06:02:00)"
UniqueID=INTEGER|1193566054
periodicity=STRING|"1"
periodparameter=STRING|"0010000"
periodparameter2=STRING|"11111"
startdate=STRING|"44856"
time0=STRING|"21720000"
timecount=STRING|"1"
wakeup=STRING|"0"
