Bug with new versions of Powershell
DK.Ideagen
Post by DK.Ideagen »
If I run a powershell script and set the path to powershell to pwsh ie use powershell core the newest version I get an invocation error despite powershell core working perfectly everywhere else.
I have tried ms store, scoop and direct install types of Powershell version 7.2.6 all fail
path to shell
path to shell
Re: Bug with new versions of Powershell
"pwsh" is not a path...
You must specify the full path to installed powershell application
Like this:
C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe
Also I think that you have incorrect installation of Powershell application
I tried to download new powershell from MS Store, it works (see screenshot)
DK.Ideagen
Discovered my problem I had a
cls
command at the top of my $profile
to clear the screen
this ran a function to get the mouse cursor which robotask failed on.
I think that cls command has no sense in Powershell script action, because this action has no UI at running...
DK.Ideagen
You are correct, However the cls command was coming from my $profile script which runs on every powershell session like a .rc file on linux.
This includes RoboTask.
I have removed the offending line from my profile anyway. So problem worked around and debugged. :)
