Decimal numbers operations
marcolobaido
Post by marcolobaido »
Hi, can I add two decimal numbers using the arithmetical operation feature?
Re: Decimal numbers operations
If you want to use the real numbers (non-integer) use quotes
like this
{Add("17,56","8,92")}
also look at the example below
ExternalName=STRING|"Task1041"
ID=INTEGER|1172306503
Name=STRING|"Show ""{Add(""17,56"",""8,92"")}""..."
Name=STRING|"Show ""{Add(""17,56"",""8,92"")}"""
msg0=STRING|"{Add(""17,56"",""8,92"")}"
But please note the decimal divider can be dot "." or comma "," in different regional settings.
