Email when Error
jpaulcr
Email when Error
Post by jpaulcr »
Does anyone of you guys know if it is possible to have an email sent if the task has an error when executing?
I know it is possible to use the variable {IsError} to check if there was an error in the PREVIOUS step. The problem is that I don't want to check for errors in each of my key steps. I was wondering if there was something like IF there was an error in one of the steps THEN send email.
Thanks,
Jean-Paul
markus
Email when Error
Post by markus »
I would be very happy if anyone has a solution for this "problem".
Thank you,
Markus
Email when Error
See such algorithm
Set Variable ErorCount to 0
critical step 1
if {IsError} then
   increment variable ErorCount on 1
end if
critical step 2
if {IsError} then
end if
critical step 3
if {IsError} then
end if
if ErorCount > 0 then
   Show Message "ALARM!!!"
end if
