Check if variable is numeric
sarnusch
Post by sarnusch »
Because I want to save edited images automatically into another folder, the source file name (e.g. 1234567.jpg or 1234567_v1.jpg) must be checked.
The file name must be numeric with the exception of the letter 'v' (for 'version') and the special charater '_' and must not contain any other letters or special characters.
I did not find a possibility to check this in a smart way.
Is there a solution to do this with RoboTask?
Kind regards,
Sebastian
Re: Check if variable is numeric
You can use regular expression to check name
Expression is:
(?i)^(\d+|\d+_v\d+)\.jpg$
Also look at complete example (look at the step #3)
ExternalName=STRING|"Task1468"
ID=INTEGER|-1708117588
Name=STRING|"check file name"
ToLog=INTEGER|2
Name=STRING|"Set variable ""Names"" File names list"
varname=STRING|"Names"
varvalue=STRING|"1234567.jpg{EOL}1234567_v1.jpg{EOL}1234567_v5.jpg{EOL}DSC_1746.jpg"
Name=STRING|"Text Loop"
destvar=STRING|"LINE"
line0=STRING|"{Names}"
sourcetext=STRING|"1"
Name=STRING|"RegExp Match"
anchored=STRING|"0"
extended=STRING|"0"
line00000000=STRING|"{line}"
multiline=STRING|"0"
noautocapture=STRING|"0"
pattern=STRING|"(?i)^(\d+|\d+_v\d+)\.jpg$"
savesubexpression=STRING|"0"
singleline=STRING|"0"
subexpressionpos=STRING|"0"
ungreedy=STRING|"0"
useexternal=STRING|"0"
variable=STRING|"valid"
value1=STRING|"{Valid}"
message=STRING|"{line} is valid"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
message=STRING|"{line} is INVALID"
type=STRING|"2"
sarnusch
Post by sarnusch »
thanks for the quick response.
I have tested it and it works fine!
I am just getting this information after using the 'Test' button even if I use real data in the 'Specified Text' field:
Screenshot 2022-07-04 110509.png (109.63 KiB) Viewed 7366 times
the string {line} does not contain necessary expression
For testing put the name explicitly and press "Test"
At runtime RoboTask expands variable and put the name instead of {line}
sarnusch
Post by sarnusch »
Hello Oleg,
ok, It was my mistake because I misunderstood the error message.
It works now as expected.
