JSON parsing sample import
DK.Ideagen
Post by DK.Ideagen »
I have found examples of JSON parsing on this forum e.g.
viewtopic.php?p=5646&hilit=json#p5646
However the samples provided do not import as valid.
Running 9.1.1
Re: JSON parsing sample import
Hm-m-m... I tried to import this task without problem in RoboTask 9.1
You can copy the text of the task and paste it into task list of RoboTask
Also look at the example how you can to do this without JS script
ExternalName=STRING|"Task1463"
ID=INTEGER|-1430236606
Name=STRING|"JSON parse (without JS script)"
Name=STRING|"Input Box"
default=STRING|"none"
password=STRING|"0"
prompt=STRING|"Input the name"
variable=STRING|"NAME"
Name=STRING|"Delete File"
Count=STRING|"1"
deletedirs=STRING|"0"
file0=STRING|"{TempDir}\gendersize.dat"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
ToRecycleBin=STRING|"0"
value1=STRING|"{name}"
value2=STRING|"none"
ActionID=STRING|"A_FLOW_EXIT"
Name=STRING|"Exit"
ActionID=STRING|"A_INET_DOWNLOAD"
Name=STRING|"Download files and save in ""{TEMPDIR}"""
action=STRING|"1"
file0=STRING|"https://api.genderize.io/?name={name}"
proxykind=STRING|"0"
saveas=STRING|"1"
saveasname=STRING|"gendersize.dat"
savedir=STRING|"{TEMPDIR}"
useproxy=STRING|"0"
Enabled=INTEGER|0
Name=STRING|"Run ""notepad.exe ""{TempDir}\gendersize.dat"""""
ifnonzero=STRING|"0"
params=STRING|"""{TempDir}\gendersize.dat"""
program=STRING|"notepad.exe"
runas=STRING|"0"
wait=STRING|"2"
ActionID=STRING|"A_SCRIPT_JSSCRIPT"
Enabled=INTEGER|0
Name=STRING|"JS script"
expandvars=STRING|"0"
line00000000=STRING|"s = RoboTaskApp().expandtext(""{TextFile({TempDir}\\gendersize.dat)}"");"
line00000002=STRING|"//LogMessage(s);"
line00000004=STRING|"obj = JSON.parse(s);"
line00000006=STRING|"//LogMessage(obj.name + ""|"" + obj.gender);"
line00000008=STRING|"if (obj.gender == null)"
line00000009=STRING|"  {RoboTaskApp().SetUserVariable(""gender"", ""UNKNOWN"");"
line0000000A=STRING|"  }"
line0000000B=STRING|"  else"
line0000000C=STRING|"  {RoboTaskApp().SetUserVariable(""gender"", obj.gender);"
line0000000D=STRING|"  }"
linecount=STRING|"16"
savescript=STRING|"0"
Name=STRING|"Set variable ""text"" with value ""{TextFile({TempDir}\gendersize.dat)}"""
varname=STRING|"text"
varvalue=STRING|"{TextFile({TempDir}\gendersize.dat)}"
Name=STRING|"Show ""full json: {text}"""
msg0=STRING|"full json: {text}"
msg1=STRING|"Name: {json:text.name}"
msg2=STRING|"Gender: {json:text.gender}"
msg3=STRING|"Probability: {json:text.probability}"
msg4=STRING|"Count: {json:text.count}"
msgcount=STRING|"5"
DK.Ideagen
perfect, thanks
