Check whether an image already exists
sarnusch
Post by sarnusch »
when I use 'Copy/Move File' I can choose what happens if the target file already exists.
Screenshot 2022-06-23 154330.png (19.9 KiB) Viewed 7204 times
In a new project I want to edit images ('Open Image', 'Resize Image', etc.) and save them to another path with the action 'Save Image'.
But here I can not check whether the image already exists in the target path or not.
Screenshot 2022-06-23 154355.png (9.67 KiB) Viewed 7204 times
Is it possible to add this function to the action 'Save Image'?
At the moment I am using a temporary folder to copy the files in a second step with the action 'Copy/ Move File'.
Re: Check whether an image already exists
OK, thanks for the suggestion.
I wrote it down in our ToDo
sarnusch
Post by sarnusch »
I think I found another workaround with an 'IfThen' and {FolderExists({TempDir})} and {FileExists({TempDir}\file.tmp)}.
Thanks for your quick reply.
sarnusch wrote: ↑Thu Jun 23, 2022 3:08 pm I think I found another workaround with an 'IfThen' and {FolderExists({TempDir})} and {FileExists({TempDir}\file.tmp)}.
This is good solution.
