download email attachments
carroll
Post by carroll »
I receive 5 emails (GMAIL) per day. Each has 1 attachment with a unique name. I am only interested in the attachments and want to save each one to a folder on drive d as a csv file.
Not sure how to get started - don't understand IMAP POP ??
I have tried to use “Pop3 download email”, How do I find the “order number of the message”
I don’t care about saving the email message or saving the attachment as a variable.
Can you refer me to a link or a youtube video that describes how ROBOTASK can do this?
Thanks Carroll
Re: download email attachments
IMAP and POP3 - are email protocols. These protocols are standard and GMAIL supports them too.
This is the ordering number of message on server. You can get it in the loop
The algorithm is similar to this
Open POP3 server
POP3 Mail loop // loop on existing messages
   If MyCondition is true then
      Download message and extract attachments
      Delete this message from server
   end if
end loop
The condition may be any. You can check the sender email or some key-phrase in email subject
Also look at my example below. It just an example
Next you can see it in the task editor
CatID=INTEGER|1163085779
ExternalName=STRING|"Task1457"
ID=INTEGER|1389483016
Name=STRING|"Get email attachment (Example)"
ActionID=STRING|"A_EMAIL_OPEN"
Name=STRING|"POP3 Open"
host=STRING|"Mail-server.com"
password=STRING|"4438845245462874500344480"
port=STRING|"995"
SSL=STRING|"1"
SSL2=STRING|"0"
SSL3=STRING|"0"
TLS10=STRING|"1"
TLS11=STRING|"1"
TLS12=STRING|"1"
user=STRING|"username"
ActionID=STRING|"A_EMAIL_LOOP"
Name=STRING|"POP3 Mail Loop"
breakafter=STRING|"0"
from=STRING|"sender"
limit=STRING|"100"
number=STRING|"num"
reverse=STRING|"0"
usecc=STRING|"0"
usedate=STRING|"0"
usefrom=STRING|"1"
usepriority=STRING|"0"
usesize=STRING|"0"
usesubj=STRING|"0"
useto=STRING|"0"
Name=STRING|"If Then //check the condition"
value1=STRING|"{sender}"
value2=STRING|"robot@myfirm.org"
ActionID=STRING|"E_EMAIL_DOWNLOAD"
Name=STRING|"POP3 Download Message"
attachfolder=STRING|"{TempDir}\attachments"
extract=STRING|"1"
num=STRING|"{num}"
overwrite=STRING|"0"
savefilenames=STRING|"0"
savetofile=STRING|"{TempDir}\{Year}{MonthNo}{Day}{Hours}{Minutes}{Seconds}{mSeconds}.eml"
ActionID=STRING|"A_EMAIL_DELETE"
Name=STRING|"POP3 Delete Email // delete downloaded email from server"
num=STRING|"{num}"
