Save Image as "JPEG"
sarnusch
Post by sarnusch »
Good afternoon,
I am testing to resize an image and save it as JPEG file.
But I am getting the following error in RoboTask:
Screenshot 2022-06-20 162642.png (40.94 KiB) Viewed 5168 times
When I use BMP it works fine.
I am using RoboTask 9.1.0.1079.
Do I have to install another image editing software to save JPEG files or can this error be fixed?
Re: Save Image as "JPEG"
You can download x32 and x64 DLLs here
Probably we forgot to include DLL into installation package...
Put this DLL into RoboTask folder or c:\windows\system32
sarnusch
Post by sarnusch »
Good morning,
I just tested it and it works fine now after putting it in the c:\windows\system32 folder.
Thanks for your quick response!
