Robotask hidden
steph@vds
Robotask hidden
Post by steph@vds »
Since a week my Robotask is hidden (instead of minimized at the left of the Date&Time icon in the task bar).
It is still running but I don't see it. Why ?
It's not a big problem but I always have a doubt : is Robotask active or not ?
Bye.
Steph@vds
Robotask hidden
You can see in "Task Manager" whether exists RoboTask process in memory or not.
Press Ctrl-Shift-Esc to launch Windows Task Manager quickly.
Robotask hidden
Some questions:
How are you starting RoboTask, as NT Service or simple application? What color of icon did you see earlier?
steph@vds
Robotask hidden
Post by steph@vds »
I start Robotask as a simple application (the icon is blue).
The process exists.
steph@vds
Robotask hidden
Do you use "Hide inactive icons" at task bar? This option is turned ON by default. Maybe system hide RoboTask icon, because you didn't use it some time.
You can change this settings. Click right mouse button on taskbar and choose Properties option and uncheck checkbox "Hide inactive icons".
steph@vds
Robotask hidden
Post by steph@vds »
Hi Oleg,
My problem is solved. I don't know how. I noticed that other applications had the same problem but now all is good.
Tanx
