Installation of Robotask-Service
userXXX
Post by userXXX »
Hello Oleg,
I am trying to install and run Robotask as a service.
On the current virtual server it seemed to work: The service ran, the Robotask application connected to the service.
But the next day the situation was different: without me changing anything, the Robotask application could no longer connect to the service ("Can't connect to host."). The service itself cannot be stopped unless Robotask is stopped via Task Manager. The situation did not change even after uninstalling and reinstalling Robotask.
Server OS is MS-Windows Server 2019 Standard.
Robotask version: 9.1.0.1079 64bit.
What could I do now?
Thank you.
Re: Installation of Robotask-Service
Open RoboTask service manager (menu Remote -> RoboTask Service Manager)
press "Service configuration" button
What string do you see in "Path to executable" field?
userXXX
Post by userXXX »
The value is:
"C:\Program Files\RoboTask\RTServiceGuard.exe"
Check the "Network server parameters" tab in RoboTask service manager
Maybe the server is not started for some reason
Also check the log file of RoboTask service:
C:\ProgramData\RoboTask\Logs\RoboTask.log
Maybe it have some error messages or warnings since last start
I tested latest version of RoboTask on our test machine under Windows 2019. It works properly.
userXXX
Post by userXXX »
These are the logfile entries of today:
I 13/06/2022 10:30:14: **** Starting RoboTask 9.1.0.1079... ************************
I 13/06/2022 10:30:14: System service mode (x64 edition)
W 13/06/2022 10:30:14: Can't set the access rights to folders and registry
I 13/06/2022 10:30:14: Load plugins...
I 13/06/2022 10:30:14: Plugin "General (v 9.1.0.354)" is loaded
I 13/06/2022 10:30:14: Plugin "Dialogs and Notifications (v 9.1.0.244)" is loaded
I 13/06/2022 10:30:14: Plugin "Files and Folders (v 9.1.0.338)" is loaded
I 13/06/2022 10:30:14: Plugin "Zip (v 9.1.0.212)" is loaded
I 13/06/2022 10:30:14: Plugin "Internet (v 9.1.0.258)" is loaded
I 13/06/2022 10:30:14: Plugin "FTP Commands (v 9.1.0.209)" is loaded
I 13/06/2022 10:30:14: Plugin "SSL FTP Commands (v 9.1.0.180)" is loaded
I 13/06/2022 10:30:14: Plugin "SFTP (SSH FTP) (v 9.1.0.116)" is loaded
I 13/06/2022 10:30:14: Plugin "Dial-Up (v 9.1.0.172)" is loaded
I 13/06/2022 10:30:14: Plugin "Variables (v 9.1.0.208)" is loaded
I 13/06/2022 10:30:14: Plugin "Task Commands (v 9.1.0.189)" is loaded
I 13/06/2022 10:30:14: Plugin "Remote Task (v 9.1.0.19)" is loaded
I 13/06/2022 10:30:14: Plugin "Loops And Flows (v 9.1.0.230)" is loaded
I 13/06/2022 10:30:14: Plugin "Window (v 9.1.0.220)" is loaded
I 13/06/2022 10:30:14: Plugin "System Events (v 9.1.0.212)" is loaded
I 13/06/2022 10:30:14: Plugin "System Functions (v 9.1.0.201)" is loaded
I 13/06/2022 10:30:14: Plugin "RoboTask Commands (v 9.1.0.176)" is loaded
I 13/06/2022 10:30:14: Plugin "Clipboard (v 9.1.0.185)" is loaded
I 13/06/2022 10:30:14: Plugin "Mouse (v 9.1.0.185)" is loaded
I 13/06/2022 10:30:14: Plugin "Registry (v 9.1.0.170)" is loaded
I 13/06/2022 10:30:15: Plugin "Network (v 9.1.0.169)" is loaded
I 13/06/2022 10:30:15: Plugin "eMail (v 9.1.0.199)" is loaded
I 13/06/2022 10:30:15: Plugin "Strings (v 9.1.0.116)" is loaded
I 13/06/2022 10:30:15: Plugin "Embedded Chromium Browser (v 9.1.0.54)" is loaded
I 13/06/2022 10:30:15: Plugin "Regular Expressions (v 9.1.0.137)" is loaded
I 13/06/2022 10:30:15: Plugin "ScreenShot (v 9.1.0.92)" is loaded
I 13/06/2022 10:30:15: Plugin "INI files (v 9.1.0.13)" is loaded
I 13/06/2022 10:30:15: Plugin "XML Document (v 9.1.0.71)" is loaded
I 13/06/2022 10:30:15: Plugin "Script Tools (v 9.1.0.30)" is loaded
I 13/06/2022 10:30:15: Plugin "Excel (v 9.1.0.63)" is loaded
I 13/06/2022 10:30:15: Plugin "Sound Volume (v 9.1.0.46)" is loaded
I 13/06/2022 10:30:15: Plugin "DataBase (v 9.1.0.62)" is loaded
I 13/06/2022 10:30:15: Plugin "Graphics (v 9.1.0.22)" is loaded
I 13/06/2022 10:30:15: Plugin "WebSockets (v 9.1.0.23)" is loaded
I 13/06/2022 10:30:15: Plugin "Console Application (v 9.1.0.14)" is loaded
I 13/06/2022 10:30:15: Load tasks...
I 13/06/2022 10:30:15: 0 tasks loaded
W 13/06/2022 10:30:15: Can't load task tree
I 13/06/2022 10:30:15: Network client is disabled in service mode.
I 13/06/2022 10:30:17: Trial mode. Network server is enabled.
I 13/06/2022 10:30:17: Preparing of network server...
