RoboTask 9.1 has been released
Locked
New version of RoboTask is ready for download. Download and try RoboTask 9.1 now
What's new in RoboTask 9.1:
Legend
[ + ] Feature added
[ - ] Bug fixed
[ * ] Modified or improved
+ Added "Format CSV line" action. Now you can change the CSV string format
in one step.
+ Added "Operations on lists". You can perform mathematical operations
on two lists: intersection, union, subtraction and symmetric difference
+ Added "TXT Delete line" action
+ Added "TXT Insert line" action
+ Added options of CSV format to action "TXT Comma-Text Conversion"
+ Addded option "Sequence number" to the action "XML Get Single Node"
+ New variable "ValidVariableName". Returns valid variable name from any string
* Fixed a memory issue. Significantly reduced the amount of memory occupied at application startup.
* Service start mode changed. Optimized work in system service mode. You need to reinstall service
* Many other small optimizations, improvements and bug fixes.
Locked
