Field data
David W.
Field data
Post by David W. »
Hi again,
I am doing a Dataset Loop and outputting the data values out to a file.  It appears to not have ALL the data in the line but has the last half of the line of data.
It appears to have something to do with the double-quotes around the string values returned from the column values.. No?
David
Field data
Dataset loop save retrieved row to user variable as comma-separated text. To access to any field you should use variable as array.
For example:
You use dataset loop and assign current row to variable named RowVar
{RowVar(0)} contains a value of first field
{RowVar(1)} - second field
{RowVar(2)} - third field
etc.
I'm afraid I haven't understood what do you mean.
David W.
Field data
Post by David W. »
Well I was happy with the comma-delimited string and just want to output that entire string to the file and not have to output each individual field using the {RowVar(0)} syntax.
Can I do that?
Field data
Yes of course. You can write comma-separated string into file via Write Text File with Append parameter within Dataset Loop.
For example:
Delete file CommaData.txt
Dataset Loop
   //append current line into end of file
   Write Text File CommaData.txt with append
end loop
As result, you will get a comma-separated text which containes the data from dataset.
Field data
See example below:
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|1272562679
ExternalName=STRING|"Task134"
ID=INTEGER|1152923633
Name=STRING|"Dataset Loop (export)"
Name=STRING|"Delete File"
Count=STRING|"1"
deletedirs=STRING|"0"
file0=STRING|"c:\data\export.txt"
subdir=STRING|"0"
ToRecycleBin=STRING|"0"
Name=STRING|"Dataset Loop"
commatext=STRING|"0"
connectionstring=STRING|"Provider=Microsoft.Jet.OLEDB.4.0;Da ta Source=C:\data\notice.mdb;Persist Security Info=False"
override=STRING|"0"
password=STRING|"1980019594193411933931376"
sql=STRING|"""select * from proposals"""
var2=STRING|"ROW"
withmemo=STRING|"0"
Name=STRING|"Create text file c:\data\export.txt"
fileexists=STRING|"1"
filname=STRING|"c:\data\export.txt"
line0=STRING|"{row}"
Name=STRING|"Remove variable ""ROW"""
varname=STRING|"ROW"
David W.
Field data
Post by David W. »
That is exactly what I am doing...
Ah, nevermind.  Sorry.  The data was bogus which made it look like it was incorrect, but in fact is correct.  Thanks.
DW
