Read in and use local variables at runtime
DK.Ideagen
Post by DK.Ideagen »
I have a text file variables.txt
it contains for as a sample
var1 = Min. horizontal separation
var2 = Min. horizontal separation unit
var3 = Angle
how can I use that file to add local variables at runtime so for example I could use {var3} in the script.
I do not wish to copy and paste the text into the task editor
Re: Read in and use local variables at runtime
look at my example
CatID=INTEGER|1163085779
ExternalName=STRING|"Task38"
ID=INTEGER|-1684481408
Name=STRING|"Load variable at runtime"
Name=STRING|"//I use variable in the task, but you can read it from file "
comment=STRING|"I use variable in the task, but you can read it from file "
Enabled=INTEGER|0
Name=STRING|"Set variable ""txt"" with value ""{TextFile(c:\temp\RuntimeVars.txt)}"" //you can read it from file"
varname=STRING|"txt"
varvalue=STRING|"{TextFile(c:\temp\RuntimeVars.txt)}"
Name=STRING|"Set variable ""txt"" with your text"
varvalue=STRING|"var1 = Min. horizontal separation{EOL}var2 = Min. horizontal separation unit{EOL}var3 = Angle"
Name=STRING|"Text Loop"
destvar=STRING|"LINE"
line0=STRING|"{txt}"
sourcetext=STRING|"1"
Name=STRING|"Split Text"
colon=STRING|"0"
comma=STRING|"0"
other=STRING|"1"
otherchar=STRING|"="
quote=STRING|"2"
semocolon=STRING|"0"
space=STRING|"0"
spaceasone=STRING|"0"
string=STRING|"{Line}"
tab=STRING|"0"
variable=STRING|"Line"
ActionID=STRING|"A_STR_TRIM"
Name=STRING|"STR Trim"
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
source=STRING|"{Line(0)}"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
variable=STRING|"VarName"
Name=STRING|"Set variable ""{VarName}"" with value ""{Line(1)}"""
varname=STRING|"{VarName}"
varvalue=STRING|"{Line(1)}"
Name=STRING|"Show ""{var1}"""
msg0=STRING|"{var1}"
msg1=STRING|"{var2}"
msg2=STRING|"{Var3}"
msgcount=STRING|"3"
DK.Ideagen
Perfect, thank you
