DK.Ideagen
Posts: 22 Joined: Wed Mar 09, 2022 10:33 pm
Post
by DK.Ideagen » Wed Apr 27, 2022 4:13 pm
I found the following task on this form for turning CSV values into variables.
CatID=INTEGER|0
ExternalName=STRING|"Task318"
ID=INTEGER|2024929902
Name=STRING|"CSV to variables"
Name=STRING|"Open Dialog"
allowseveral=STRING|"0"
caption=STRING|"Open File"
default=STRING|"None"
filter=STRING|"*.csv"
stopifcancel=STRING|"1"
variable=STRING|"SOURCE"
Name=STRING|"Simple Loop"
begin=STRING|"1"
end=STRING|"{sz}"
variable=STRING|"NUM"
message=STRING|"var{num} = {var{num}}"
ActionID=STRING|"A_READ_TXTFILE"
Name=STRING|"Read Text File ""{SOURCE}"" (65001)"
codepage=STRING|"65001"
filename=STRING|"{SOURCE}"
replacenull=STRING|"1"
varname=STRING|"SOURCE"
ActionID=STRING|"A_TXT_COOMATEXT"
Name=STRING|"Comma-separated string -> text"
kind=STRING|"0"
line00000000=STRING|"{source}"
lines=STRING|"1"
variable=STRING|"txt"
ActionID=STRING|"A_TXT_NUMBEROFLINES"
Name=STRING|"TXT Number of Lines"
external=STRING|"0"
line00000000=STRING|"{txt}"
variable=STRING|"sz"
begin=STRING|"1"
end=STRING|"{sz}"
external=STRING|"0"
linenum=STRING|"{num}"
variable=STRING|"line"
Name=STRING|"Set variable ""VAR{NUM}"" with value ""{Line}"""
varname=STRING|"VAR{NUM}"
varvalue=STRING|"{Line}"
message=STRING|"Soutce = {Source}"
E.g. If however, I pass it a CSV containing Sonic, The Hedgehog I get three variables.
It Appears to be splitting on paste why is this and how can I just get
As 2 variables
PSA documents created in Microsoft Excel for testing
Posts: 3278 Joined: Thu Jan 01, 1970 1:00 am
Post
by Oleg » Wed Apr 27, 2022 4:43 pm
The string
is not standard comma-separated string
Standard coma-separated string is
To bring your string to standard mode use
Split text action
Also look at my example (see step#4)
ExternalName=STRING|"Task1351"
ID=INTEGER|744873048
Name=STRING|"Comma separated demo"
Name=STRING|"Set variable ""line"" with value ""Sonic,The Hedgehog"""
varname=STRING|"line"
varvalue=STRING|"Sonic,The Hedgehog"
kind=STRING|"0"
line00000000=STRING|"{line}"
lines=STRING|"1"
Name=STRING|"Show ""{Line}"""
msg0=STRING|"{Line}"
msg1=STRING|"=================="
msg2=STRING|"{txt}"
msgcount=STRING|"3"
Name=STRING|"Split Text"
colon=STRING|"0"
comma=STRING|"1"
other=STRING|"0"
quote=STRING|"0"
semocolon=STRING|"0"
space=STRING|"0"
spaceasone=STRING|"0"
string=STRING|"{line}"
tab=STRING|"0"
kind=STRING|"0"
lines=STRING|"1"
msg2=STRING|"{txt}"
msgcount=STRING|"3"
DK.Ideagen
Post
by DK.Ideagen » Thu Apr 28, 2022 8:46 am
I have adapted the above into my task.
It is working, however I really need the ultimate data to not be wrapped in double quotes.
Is there an easy way to achieve this?
Post
by Oleg » Thu Apr 28, 2022 9:22 am
You can use any string format.
But it you want to process string as comma-separated string in RoboTask you must to convert string into standard format.
You can combine the string without quotes, no problem
But what do you du if your element contains comma char?
for example
first element
second element
this, comma test
When you will convert this to CSV line without quotes the line will contain 4 elements instead of 3
DK.Ideagen
Post
by DK.Ideagen » Thu Apr 28, 2022 10:03 am
To clarify
Splitting on comma is wanted
just not on space
I added double quotes so
is split into two lines
not
In reality I want
but only split on commas
Post
by Oleg » Thu Apr 28, 2022 12:05 pm
Look at this example
To get it work as you want you must add only one step (see step #2, Split Text)
Is this a problem?
colon=STRING|"0"
comma=STRING|"1"
other=STRING|"0"
quote=STRING|"0"
space=STRING|"0"
tab=STRING|"0"
variable=STRING|"TmpLine"
kind=STRING|"0"
line00000000=STRING|"{TmpLine}"
lines=STRING|"1"
Name=STRING|"Show ""Source line: {Line}"""
msg0=STRING|"Source line: {Line}"
msg2=STRING|"result text:"
msg3=STRING|"{txt}"
msgcount=STRING|"4"
DK.Ideagen
Post
by DK.Ideagen » Fri May 06, 2022 9:18 am
I fixed this with a python script to
Post
by Oleg » Fri May 06, 2022 9:49 am
DK.Ideagen wrote: ↑ Fri May 06, 2022 9:18 am
There is the action
STR Replace
You can use it instead of python
