csv file
dondada
csv file
Post by dondada »
I need a task that will "look" at a csv file and save each row of data to a separate file. I the original file has 5 rows then I should end up with 5 files. If the original file has 8 rows then I need 8 files. Each file must contain just one row of data. How do I do that? Thanks for the help.
csv file
See example below. This task save each line of text into separate file. Each file have name FileName_lineN.ext where
FileName - original filename;
ext - original extension;
N - line number.
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|1614811947
ExternalName=STRING|"Task392"
ID=INTEGER|1546359054
Name=STRING|"one line per file"
Name=STRING|"Open Dialog"
caption=STRING|"Open File"
default=STRING|"None"
variable=STRING|"FILE_TO_PROCESS"
Name=STRING|"Remove variable ""NEWFILENAME"""
varname=STRING|"NEWFILENAME"
Name=STRING|"Remove variable ""CUR_LINE"""
varname=STRING|"CUR_LINE"
Name=STRING|"Set variable ""NUM"" with value ""1"""
varname=STRING|"NUM"
varvalue=STRING|"1"
Name=STRING|"Text Loop"
destvar=STRING|"CUR_LINE"
file=STRING|"{file_to_process}"
linecount=STRING|"0"
sourcetext=STRING|"0"
Name=STRING|"Set variable ""NEWFILENAME"" with value ""{ExtractFilePath({File_to_process})}\{ExtractFileNameNoExt ({File_to_process})}_Line{num}.{ExtractFileExt({File_to_proc ess})}"""
varvalue=STRING|"{ExtractFilePath({File_to_process})}\{Extra ctFileNameNoExt({File_to_process})}_Line{num}.{ExtractFileEx t({File_to_process})}"
Enabled=INTEGER|0
Name=STRING|"Show ""{NewFileName}"""
msg0=STRING|"{NewFileName}"
Name=STRING|"Create text file {NewFileName}"
fileexists=STRING|"0"
filname=STRING|"{NewFileName}"
line0=STRING|"{Cur_Line}"
incement=STRING|"1"
vaiable=STRING|"num"
Name=STRING|"Remove variable ""NUM"""
