Scheduler - Run once
vane
Post by vane »
How to set a task for running once? There's no end date in Scheduler. Thanks.
Re: Scheduler - Run once
  • Open task editor
  • Go to Advanced tab
  • Set Disable task option in Action after completion parameter
RoboTask disables the task when it completes and stops all triggers.
If you want to run the task automatically again just enable the task.
vane
Post by vane »
Thank you for the reply.
By the way, there are three options for Action After Completion in the User's Guide. However, Delete Task is not shown in the software. Will this feature be added soon?
Advanced tab is described here: https://robotask.com/help/index.html?tasknew.htm#3
We removed option Delete Task consciously. You must remove task manually
vane
Post by vane »
I see. Please modify the User's Guide. Thanks.
