RoboTask 9.0 has been released
Locked
New version of RoboTask is ready for download. Download and try RoboTask 9.0 now
What's new in RoboTask 9.0:
Legend
[ + ] Feature added
[ - ] Bug fixed
[ * ] Modified or improved
+ Completely updated graphical elements of GUI (icons and images) for compatibility with Hi-res monitors
+ Redesigned interface of the main application window
+ Redesigned the task editor. Actions and triggers lists are included into editor interface.
+ Added task result. To return some result, simply set the task's variable named TaskResult.
* Improved several date-time variables:
  • Day
  • DayOfWeek
  • DayOfWeekNo
  • Hours
  • Minutes
  • MonthName
  • MonthNo
  • Seconds
  • ShortDayOfWeek
  • ShortMonthName
  • ShortYear
  • Time
  • Year
These variables can take a date and time value as a parameter. If the
parameter is missing, then the variables return the value for the
current date and time.
* Improved all "waiting" actions. You can choose an action:
  • raise Timeout error
  • set TRUE or False to variable
The actions are: * Many other small optimizations, improvements and bug fixes.
Locked
