Dialog possible to be configured Modal, on top
User avatar
robotask
Post by robotask »
Is it possible to define a Dialog to be modal
Currently, Firefox is my main working window and Dialog detects the window title change and opens but behind firefox.
This is totally random and I have a workaround by creating another task that looks for the dialog window title, minimizes it and then restores it. While this works, it is annoying.
Re: Dialog possible to be configured Modal, on top
Unfortunately, this effect appears randomly.
There is a mechanism in the code for this dialog to bring it to the top, but sometimes it fails.
User avatar
robotask
Post by robotask »
Another annoying 'feature' present also in version 9 is that dialog requires two(2) clicks, one from the list of items and second click from Ok.
With version 7, using scripting, it is a single click from dialog to move process
