Basic Plugin
steph@vds
Basic Plugin
Post by steph@vds »
I've discovered your new Plug-in "Basic Script".
It seems very interesting but a little complex for me.
I know that you can't explain to everybody the Basic Script Language
but is it possible to get a simple example of Basic Script just to make
simple operations (addition, substraction etc.)
I tried to do this in the following task but I don't know how to show the result of my operation in Robotask.
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|1572434964
ExternalName=STRING|"Task94"
ID=INTEGER|1243614119
Name=STRING|"CALCUL TEST 1"
Name=STRING|"Create variable ""PARAMETER_A"" with value """""
varname=STRING|"PARAMETER_A"
Name=STRING|"Create variable ""PARAMETER_B"" with value """""
varname=STRING|"PARAMETER_B"
Name=STRING|"Input Box"
default=STRING|"0"
prompt=STRING|"Quelle est la durée du film ? (en min)"
variable=STRING|"PARAMETER_A"
default=STRING|"0"
prompt=STRING|"Quel sera le débit ? (en kbits/sec)"
variable=STRING|"PARAMETER_B"
Name=STRING|"Basic Script"
line00000=STRING|"Sub Main"
line00001=STRING|"    Dim a As Double"
line00002=STRING|"    Dim b As Double"
line00004=STRING|"    a = Val (RoboTaskApp.ExpandText(""{Parameter_a}""))"
line00005=STRING|"    b = Val (RoboTaskApp.ExpandText(""{Parameter_b}""))"
line00007=STRING|"    d = (b+192)*a*60*1.013/1000/1000/8"
line00009=STRING|"End Sub"
linecount=STRING|"10"
source=STRING|"0"
Name=STRING|"Remove variable ""PARAMETER_A"""
Name=STRING|"Remove variable ""PARAMETER_B"""
Thanx
Steph@vds
Basic Plugin
No problem. Use RoboTaskApp.SetUserVariable method. Also, you can use BASIC procedure MsgBox (refer to BASIC help).
See task below.
;* Do not edit!       *
CatID=INTEGER|1614811947
ExternalName=STRING|"Task389"
default=STRING|"0"
default=STRING|"0"
line00009=STRING|"    RoboTaskApp.SetUse rVariable(""Result"",Str(d))"
line00011=STRING|"End Sub"
linecount=STRING|"12"
source=STRING|"0"
Name=STRING|"Show ""result is {result}"""
msg0=STRING|"result is {result}"
Basic Plugin
For simple calculations you can use Evaluate action.
But I advise you to use brackets "()" in expression.
See task below:
;* Do not edit!       *
ExternalName=STRING|"Task390"
ID=INTEGER|1148674652
Name=STRING|"CALCUL TEST 2"
default=STRING|"0"
default=STRING|"0"
Name=STRING|"Evaluate"
expression=STRING|"({Parameter_b}+192)*(({parameter_a}*60)*1 .013)/1000/1000/8"
variable=STRING|"RESULT"
Enabled=INTEGER|1
Enabled=INTEGER|1
steph@vds
Basic Plugin
Post by steph@vds »
It's simply wonderful !
Thanks
