I am trying to convert an excel spreadsheet into a suitable Variables XML file.
I have exported an example from robotask and used that as a XML map (image attached)
I have added a name field and ID for the folder level but still can't export.
Can someone please provide a template if possible.
ty
Excel to XML global variable import
DK.Ideagen
- Attachments
- syjqmM64iy.png (138.52 KiB) Viewed 9225 times
Re: Excel to XML global variable import
I can assist you to export data into custom XML structure by using RoboTask functions
But I don't know how to do this in EXCEL. EXCEL can save document to XML with very complex structure.
Could you send small XML with several items you want to get? Enough 2-3 elements to understand the structure
I found your question in stackoverflow
Look at this example (below). It creates the XML you want.
CatID=INTEGER|1163085779
ExternalName=STRING|"Task180"
ID=INTEGER|1124069604
Name=STRING|"Create XML from EXCEL"
Action14=FOLDER
Action15=FOLDER
filename=STRING|"D:\Temp\TestBook.xlsx"
hide=STRING|"0"
mode=STRING|"0"
tryconnect=STRING|"0"
ActionID=STRING|"A_XML_ADDCHILD"
Name=STRING|"XML Add Childnode //add value"
child00000000=STRING|"<value type=""STRING"">{val}</value>"
childcount=STRING|"1"
parent00000000=STRING|"{Item}"
parentcount=STRING|"1"
variable=STRING|"item"
Name=STRING|"XML Add Childnode // add to root"
child00000000=STRING|"{Item}"
parent00000000=STRING|"{rootXML}"
variable=STRING|"rootXML"
Enabled=INTEGER|0
Name=STRING|"Show Text"
[Actions\Action12\Params]
autoclose=STRING|"0"
fromfile=STRING|"1"
line00000000=STRING|"{rootXML}"
timeout=STRING|"10"
[Actions\Action14]
ActionID=STRING|"A_XML_SAVE"
Name=STRING|"XML Save to D:\Temp\TestBook.xml"
[Actions\Action14\Params]
filename=STRING|"D:\Temp\TestBook.xml"
ifexists=STRING|"1"
xml00000000=STRING|"{RootXML}"
xmlcount=STRING|"1"
[Actions\Action15]
[Actions\Action15\Params]
fromfile=STRING|"0"
timeout=STRING|"10"
title=STRING|"Result XML"
ActionID=STRING|"A_XML_CREATENODE"
Name=STRING|"XML Create Node ""Root"" and save to ""rootXML"""
attcount=STRING|"0"
name=STRING|"Root"
txtcount=STRING|"0"
Name=STRING|"Simple Loop"
begin=STRING|"2"
end=STRING|"1000"
variable=STRING|"ROW"
ActionID=STRING|"A_EXCEL_GET"
Name=STRING|"Excel Get Cells"
cell00000000=STRING|"R{row}C1"
cell00000001=STRING|"R{row}C2"
cell00000002=STRING|"R{Row}C3"
count=STRING|"3"
var00000000=STRING|"id"
var00000001=STRING|"nm"
var00000002=STRING|"val"
worksheet=STRING|"1"
operator=STRING|"7"
value1=STRING|"{id}"
Name=STRING|"Break"
Name=STRING|"XML Create Node ""{id}"" and save to ""item"""
att00000000=STRING|"type,FOLDER"
attcount=STRING|"1"
name=STRING|"{id}"
txtcount=STRING|"0"
Name=STRING|"XML Add Childnode // add name"
child00000000=STRING|"<name type=""STRING"">{nm}</name>"
I shortened and simplified the task a little.
see below
see below
ExternalName=STRING|"Task362"
ID=INTEGER|-1429457164
Name=STRING|"Create XML from EXCEL-2"
hide=STRING|"0"
mode=STRING|"0"
ActionID=STRING|"A_EXCEL_CLOSE"
Name=STRING|"Excel Close"
ifexists=STRING|"1"
xmlcount=STRING|"1"
[Actions\Action13\Params]
fromfile=STRING|"0"
timeout=STRING|"10"
attcount=STRING|"0"
name=STRING|"Root"
txtcount=STRING|"0"
begin=STRING|"2"
end=STRING|"1000"
count=STRING|"3"
operator=STRING|"7"
Name=STRING|"Break"
child00000000=STRING|"<{id} type=""FOLDER"">"
child00000001=STRING|" <name type=""STRING"">{nm}</name>"
child00000002=STRING|" <value type=""STRING"">{val}</value>"
child00000003=STRING|"</{id}>"
childcount=STRING|"4"
Enabled=INTEGER|0
fromfile=STRING|"1"
timeout=STRING|"10"
DK.Ideagen
Thank you so much Oleg finally seen this.
I have improved the above task to ask for a file.
It works perfectly.
One potential additional improvement / question.
I attempted to avoid hardcoding the user path e.g. by using
as a path.
Yet this is evaluated as
Would it be possible to fix this?
It works perfectly.
%UserProfile%\Desktop\XMLtoImport.xmlYet this is evaluated as
RobotaskDirectory/%UserProfile%/.....
CatID=INTEGER|0
Name=STRING|"Create XML from EXCEL-2 (imported)"
Name=STRING|"Open Dialog"
allowseveral=STRING|"0"
caption=STRING|"Open File"
default=STRING|"None"
filter=STRING|"*"
stopifcancel=STRING|"0"
variable=STRING|"FILE"
Name=STRING|"XML Save to C:\Users\daniel.kendall\OneDrive - Ideagen plc\Desktop\xmltoImport.xml"
filename=STRING|"C:\Users\daniel.kendall\OneDrive - Ideagen plc\Desktop\xmltoImport.xml"
ifexists=STRING|"1"
xmlcount=STRING|"1"
fromfile=STRING|"0"
timeout=STRING|"10"
filename=STRING|"{file}"
hide=STRING|"0"
mode=STRING|"0"
attcount=STRING|"0"
name=STRING|"Root"
txtcount=STRING|"0"
begin=STRING|"2"
end=STRING|"1000"
cell00000002=STRING|"R{row}C3"
count=STRING|"3"
operator=STRING|"7"
Name=STRING|"Break"
There is EnvironmentVar system variableDK.Ideagen wrote: ↑Fri Mar 25, 2022 12:06 pm One potential additional improvement / question.
I attempted to avoid hardcoding the user path e.g. by usingas a path.Code: Select all
Yet this is evaluated asWould it be possible to fix this?Code: Select all
Use the expression
{EnvironmentVar(UserProfile)}\Desktop\XMLtoImport.xml
ExternalName=STRING|"Task1382"
ID=INTEGER|-811450540
Name=STRING|"Environment variable"
OnErrorTaskID=INTEGER|200524284
Name=STRING|"Show ""{EnvironmentVar(UserProfile)}\Desktop\XMLtoImport.xml"""
msg0=STRING|"{EnvironmentVar(UserProfile)}\Desktop\XMLtoImport.xml"
DK.Ideagen
Perfect thank you
