Date of next Sunday
renders
Date of next Sunday
Post by renders »
Hi all.. I have a need to copy a file from a folder that is named \MONTH DAY\text.docx.
The folder name is based on the date of next Sunday. The task is scheduled 5 days before the actual Sunday.
For most Sundays, I can use the {MonthName} variable for the first part. And a local variable based on a VB Evaluate of {Day}+(8-{DayOfWeekNo})
However, there will be some times when the Sunday might be in the next month..
Can you suggest the simplest way to create this?
Thanks for your advice..
Rob
renders
Re: Date of next Sunday
Post by renders »
I tried using {MonthIncDays(+(8-{DayOfWeekNo}))} but get a type mismatch.
Look at my example below
CatID=INTEGER|1163085779
ExternalName=STRING|"Task38"
ID=INTEGER|-1797697898
Name=STRING|"Date of next sunday"
Name=STRING|"VB Evaluate (calculate delta)"
expression=STRING|"8 - {DayOfWeekNo}"
linecount=STRING|"0"
loadfromfile=STRING|"1"
variable=STRING|"delta"
Name=STRING|"Show ""Date of next sunday: {DateIncDays({delta})}"""
msg0=STRING|"Date of next sunday: {DateIncDays({delta})}"
Copy text of the task and paste into RoboTask task list
