Google 2-Step Verification VS send mail action
marcolobaido
Post by marcolobaido »
Hi, I activated the 2 step verification in my gmail account. After this modify, the "send mail" action doesn't work.
E: 18/02/2022 13:26:40: Error occurred: Application-specific password required. Learn more at
E: 18/02/2022 13:26:40: https://support.google.com/mail/?p=InvalidSecondFactor 9sm2235513ejk.28 - gsmtp
E: 18/02/2022 13:26:40: An error occurred. Step #24 (Send Email).
E: 18/02/2022 13:26:40: Task execution is aborted
Deactivating the 2 step verification it works.
Can this be solved in any way?
P.S. (I need the 2 step verification because it's obligatory using google ads)
Re: Google 2-Step Verification VS send mail action
If your turn ON 2 step verification on Google your general password will not work in Gmail when you use non-Google applications (Thunderbird, RoboTask and so on)
You must generate new formal password if you want to access your Gmail account from 3-rd party applications.
Go to you Google account security: https://myaccount.google.com/security
and use this option (see screenshot) to add new password for your Gmail account for other applications.
marcolobaido
tcarvalho
Post by tcarvalho »
I'm having the same but inverse problem. Roughly around last week all of the "send email" steps stopped working from a gmail account I created specifically to trigger notifications for scripts. I don't have 2 factor enabled for this gmail account but out of seemingly no where Robotask generates a log message stating that "error occurred: Username and Password not accepted". I've been using these email steps for 2 years with no issues. I tried updating the gmail password but it didn't change the error message (after updating the SMTP server / mail agent tab for the send email action).
Looks like Google turned on two-factor authentication without your consent. They warned about it.
Google applications work without changes. But a third party application must be configured for this.
Cody
Post by Cody »
It seems Google change the mechanism again ? I can not find the "App password" Generator now ?
How can I do ?
Rgds,
Cody.
How can I do ?
  • Go to Google account settings
  • Click on "2-step verification" (enter your password if prompted)
  • In opened page go to the bottom and find "App passwords" chapter
Here you can make access passwords for Email programs and other non-Google applications
Cody
Post by Cody »
Oleg wrote: ↑Fri Mar 17, 2023 9:11 am
How can I do ?
Hello Oley,
Thanks, I found it through your instruction now and I will use it to download eMAIL's attachment later.
Hope I can find some useful example here.
Rgds,
Cody.
Google has changed the account admin panel a bit again.
Now the password generation for third-party applications is located here: Google account -> Security -> 2-Step Verification -> App passwords
