How to avoid RegExp add newline
adgus
Post by adgus »
When I use RegExp I got an "extra newline".. i dont know what I'm doing wrong
I made a simple task
VALUE is in one line
VALUE2 appear with 2 lines...
.. what i am doing wrong :-( ?
CatID=INTEGER|693217805
ExternalName=STRING|"Task3"
ID=INTEGER|-898941349
Name=STRING|"RegExp"
Name=STRING|"Set variable ""VALUE"" with value ""1234"""
varname=STRING|"VALUE"
varvalue=STRING|"1234"
Name=STRING|"RegExp Replace"
anchored=STRING|"0"
extended=STRING|"0"
line00000000=STRING|"{VALUE}"
multiline=STRING|"0"
noautocapture=STRING|"0"
pattern=STRING|"SDF"
replacementcount=STRING|"0"
replacemode=STRING|"0"
replinecount=STRING|"0"
singleline=STRING|"0"
ungreedy=STRING|"0"
useexternal=STRING|"0"
variable=STRING|"VALUE2"
Name=STRING|"Show Text"
autoclose=STRING|"0"
fromfile=STRING|"1"
line00000000=STRING|";{VALUE};"
line00000002=STRING|";{VALUE2};"
linecount=STRING|"3"
timeout=STRING|"10"
title=STRING|"VALUE"
Re: How to avoid RegExp add newline
Thank you for your report
We'll investigate the problem. It seems this is malfunction.
