RoboTask 8.6 has been released
Locked
New version of RoboTask is ready for download. Download and try RoboTask 8.6 now
What's new in RoboTask 8.6:
Legend
[ + ] Feature added
[ - ] Bug fixed
[ * ] Modified or improved
+ New plugin "INI files". New actions: + Added GetTaskResult variable. You can get the latest task result by
task ID or external name
+ Modified Task start action. You can save the task result in a variable
+ Modified Start remote task action. You can save the task result in a variable
+ Added "Use Full Desktop" option for screenshot actions.
* Improved action "SFTP Log On". You can output the connection process to
the task log for monitoring.
* Optimized all actions for the RoboTask shutdown process.
* Improved task tree in the main window.
* Improved Task editor
* Many other small optimizations, improvements and bug fixes.
Locked
