Missing Tasks Pane
krhoades
Missing Tasks Pane
Post by krhoades »
My Tasks Pane is missing and I cannot figure out how to get it back? Any suggestions? I noticed the File with eyeball is missing?
Re: Missing Tasks Pane
Try to do the following
  • stop RoboTask (menu Task->Stop or CTRL+X)
  • open REGEDIT system utility
  • remove registry key HKEY_CURRENT_USER\SOFTWARE\TaskAutomation\RoboTask\Settings\Forms
  • Start RoboTask again.
Probably saved form properties contain some incorrect values.
krhoades
Post by krhoades »
That did the trick, thank you!
