How can I upload a many files?
sara00
Post by sara00 »
I have, for example, a number of text files 1.txt , 2 txt , 3.txt 4.txt 5.txt
I want the program to choose them when uploading to the site in the order file by file ..
I also want to save their links all in a text file
Re: How can I upload a many files?
You can upload files by using FTP or sFTP protocols
algorithm will be similar to my example (see below)
CatID=INTEGER|1163085779
ExternalName=STRING|"Task61"
ID=INTEGER|-1442708484
Name=STRING|"Upload files"
Name=STRING|"Set variable ""FileList"" with value ""c:\incoming\1.txt{EOL}c:\incoming\2 txt{EOL}c:\incoming\3.txt{EOL}c:\incoming\4.txt{EOL}c:\incoming\5.txt"""
varname=STRING|"FileList"
varvalue=STRING|"c:\incoming\1.txt{EOL}c:\incoming\2 txt{EOL}c:\incoming\3.txt{EOL}c:\incoming\4.txt{EOL}c:\incoming\5.txt"
ActionID=STRING|"A_SSLFTP_LOGON"
Name=STRING|"SSL FTP Log On"
anonymous=STRING|"1"
host=STRING|"localhost"
passive=STRING|"1"
port=STRING|"21"
proxypassword=STRING|"2540124941259682545026731"
proxytype=STRING|"3"
tlsmode=STRING|"0"
useproxy=STRING|"0"
username=STRING|"anonymous"
usessl2=STRING|"0"
usessl3=STRING|"0"
usestls=STRING|"1"
usestls11=STRING|"1"
usestls12=STRING|"1"
Name=STRING|"Text Loop"
destvar=STRING|"FILETOUPLOAD"
line0=STRING|"{FileList}"
sourcetext=STRING|"1"
ActionID=STRING|"A_SSLFTP_UPLOAD"
Name=STRING|"SSL FTP Upload"
file=STRING|"{FileToUpload}"
folder=STRING|"/ftpfolder"
ifexists=STRING|"0"
