Email
NoMercy
Email
Post by NoMercy »
In the action Send Email, I'm trying to use a variabel in the To: item.
But I get a error, invalid adress.
I is not possible use variables in the To: item?
Håkan in Sweden
Email
Probably you are doing something wrong or your variable not contain valid email address. See the example below. I've just tested this. It's working fine.
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|188537163
ExternalName=STRING|"Task131"
ID=INTEGER|1245391391
Name=STRING|"Send email test"
Name=STRING|"Set variable ""TO_MAIL"" with value ""oleg@robotask.com"""
varname=STRING|"TO_MAIL"
varvalue=STRING|"oleg@robotask.com"
Name=STRING|"Send Email"
attachcount=STRING|"0"
auth=STRING|"0"
from=STRING|"oleg@robotask.com"
host=STRING|"localhost"
html=STRING|"0"
msg0=STRING|"This is a test only"
password=STRING|"2488925202262242647415210"
port=STRING|"25"
subject=STRING|"This is a test message"
to=STRING|"{to_mail}"
NoMercy
Email
Post by NoMercy »
Thanks,
It works fine with one, I forgot to tell you, it is when I use 2 emailadresses in a variable I get the error.
/Håkan
Email
Thank you, you've found a bug. We shall fix it in next release necessarily. Try to send mail with using text loop now. See example below.
;* Do not edit!       *
CatID=INTEGER|782314203
ExternalName=STRING|"Task371"
ID=INTEGER|1550773634
Name=STRING|"Send email test (by loop)"
Name=STRING|"Text Loop"
destvar=STRING|"TO_MAIL"
line0=STRING|"oleg@robotask.com"
line1=STRING|"oleg@robotask.com"
linecount=STRING|"2"
sourcetext=STRING|"1"
auth=STRING|"0"
html=STRING|"0"
password=STRING|"2514524939246812673840557"
port=STRING|"25"
NoMercy
Email
Post by NoMercy »
OK,
My case is, I'm using the Basiccode to run a select case on the 4 first letters in a filename. Depend on which file, I will set the mailvariable with different recivers. Sometimes I have more than one adress to send.
/Håkan
