copy folder from network path to local drive
mohi
Post by mohi »
Hi
i want to make a job that copy folder or files from network path to local drives. but in synchronize Folders action i cant see the network map drives. is it possible to use network path and drives to copy files or folders?
Re: copy folder from network path to local drive
Please note if you man some network drive then this works only within your session.
Another session can have another settings.
If you want to use some universal name use UNC names.
For example, instead of the path
z:\documents\report.doc
you can use
\\server1\incoming\documents\report.doc
A UNC name is formed in the following way:
\\<Server_Name>\<Resource>\<subfolders>\<file_name>
