3 states: How do use it proper with 2 If , ElseIf statements
snowseals
Post by snowseals »
I'm trying to run 3 different scripts, depending on the visual representation of a certain site.
There are 3 visual representations:
I'm using Screen Pixel and Local Variables along with Color Compliance to decide which script to run.
It works, but sometimes it's still running the wrong script.
What I'm I doing wrong?
CatID=INTEGER|0
ExternalName=STRING|"Task16"
ID=INTEGER|1660370954
Name=STRING|"05   AutotelexPRO invullen + Eurotax openen tm 2017 vs 2018 vs 2020 (imported)"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
ActionID=STRING|"A_SCR_SCRPIXEL"
Name=STRING|"Screen Pixel"
monitor=STRING|"0"
useprimary=STRING|"1"
variable=STRING|"colorWhite"
x=STRING|"1159"
y=STRING|"429"
Enabled=INTEGER|0
Name=STRING|"Break"
ActionID=STRING|"A_FLOW_ELSEIF"
Name=STRING|"ElseIf Then"
case#1=STRING|"0"
count=STRING|"2"
operator#1=STRING|"1"
type#1=STRING|"3"
value1=STRING|"{ColorMatcheda}"
value1#1=STRING|"{ColorMatchedb}"
Enabled=INTEGER|0
Name=STRING|"Show ""2018 - Point color is white but NOT beige."""
[Actions\Action12\Params]
msg0=STRING|"2018 - Point color is white but NOT beige."
Name=STRING|"Start Task ""2018 - 05  AutotelexPRO invullen + Eurotax openen!"""
[Actions\Action13\Params]
parametercount=STRING|"0"
required=STRING|"0"
taskid=STRING|"265965612"
wait=STRING|"1"
[Actions\Action14]
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
[Actions\Action15]
Enabled=INTEGER|0
Name=STRING|"Show ""2020 """
[Actions\Action15\Params]
msg0=STRING|"2020 "
[Actions\Action16]
Name=STRING|"Start Task ""2021  05  AutotelexPRO invullen + Eurotax openen!"""
[Actions\Action16\Params]
required=STRING|"0"
taskid=STRING|"691894826"
wait=STRING|"1"
[Actions\Action17]
monitor=STRING|"0"
variable=STRING|"colorBeige"
x=STRING|"1162"
y=STRING|"446"
Name=STRING|"Create local variable ""COLORMATCHEDa"" with value ""whiteVariable"""
varname=STRING|"COLORMATCHEDa"
varvalue=STRING|"whiteVariable"
Name=STRING|"Create local variable ""COLORMATCHEDb"" with value ""beigeVariable"""
varname=STRING|"COLORMATCHEDb"
varvalue=STRING|"beigeVariable"
ActionID=STRING|"A_SCR_COLORCOMPLIANCE"
Name=STRING|"Color Compliance"
color1=STRING|"{colorWhite}"
color2=STRING|"$00FFFFFF"
tolerance=STRING|"0"
variable=STRING|"ColorMatcheda"
color1=STRING|"{colorBeige}"
color2=STRING|"$00EDF1F2"
variable=STRING|"ColorMatchedb"
case#1=STRING|"0"
count=STRING|"2"
operator#1=STRING|"0"
type#1=STRING|"3"
Enabled=INTEGER|0
Name=STRING|"Show ""2017 - Point color is white AND beige."""
msg0=STRING|"2017 - Point color is white AND beige."
Name=STRING|"Start Task ""05  AutotelexPRO invullen + Eurotax openen!"""
required=STRING|"0"
taskid=STRING|"1990679332"
wait=STRING|"1"
Re: 3 states: How do use it proper with 2 If , ElseIf statem
Look at the steps #5 and #6 (color compliance)
I think that you don't need to use exact comparison. Set tolerance to 8 or 4.
Probably the the real color may differ from the specified sometimes.
For example it may happen when you work on local console or through RDP session.
snowseals
Post by snowseals »
Interesting.
I will set both to 8 tolerance to see if it won't occur this way.
NOTE:
I'm not using Remote Desktop or any other, also its not a laptop (which could change color due battery mode / dim-mode vs. when on electrical socket charger)
snowseals
Post by snowseals »
I have tried to replicate and even on 8 and 16 tolerance it still happens.
notice how 2017 is run (ok) and the next instance 2020 script (not ok) then after a few attempts 2017 is run again (ok)
https://i.imgur.com/BdDUbFe.mp4
I see that you run the task from command line from system menu "start"
Pay attention that this menu is above your target form.
I think that sometimes the task takes a screenshot when menu is on the screen yet. So the task takes incorrect screenshot and get incorrect pixels.
System starts the command line immediately and hides the menu some later.
I got such effect during my testing earlier.
Run this task by HotKey trigger or put some pause at 1-st step of the task
snowseals
Post by snowseals »
I think you are right - the black CLI window shows a fraction, which is probably the culprit..
I've now set a DELAY of 200 ms in front, and so far it's solid.
Thanks again Oleg!
Consider it solved. :idea:
