Posts: 238 Joined: Mon Feb 22, 2016 4:06 pm
Post
by Rukbunker » Thu Sep 02, 2021 11:46 am
Hey Oleg,
There are similar topics here which all partly answer my question, hence this specific topic.
We have a task coming up (as a pilot) which should declare some variables at once. The input is a CSV (or similar). For every line in the CSV, Robotask should do something. (Yes, the loop comes in here
The CSV looks like:
Customernumber,CustomerName,Mail
000001,Robotask,info@dummymail.hay
000052,YankyDoodle,dontwrite@mail.co.uk.br.tr
With every loop, I want to declare the values per line all at once to different variables.
What is your best approach?
Posts: 3310 Joined: Thu Jan 01, 1970 1:00 am
Post
by Oleg » Thu Sep 02, 2021 12:25 pm
Look at examples below
The simplest way to set each element to separate variable from comma-separate string
CatID=INTEGER|1163085779
ExternalName=STRING|"Task1416"
ID=INTEGER|-369271517
Name=STRING|"Set variables from list"
ToLog=INTEGER|2
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Name=STRING|"Set variable ""list"" (source text)"
varname=STRING|"list"
varvalue=STRING|"Customernumber,CustomerName,Mail{EOL}000001,Robotask,info@dummymail.hay{EOL}000052,YankyDoodle,dontwrite@mail.co.uk.br.tr"
Name=STRING|"Set variable ""CustomerNum"" with value ""{Line(0)}"""
varname=STRING|"CustomerNum"
varvalue=STRING|"{Line(0)}"
Name=STRING|"Set variable ""CustomerName"" with value ""{Line(1)}"""
varname=STRING|"CustomerName"
varvalue=STRING|"{Line(1)}"
Name=STRING|"Set variable ""mail"" with value ""{Line(2)}"""
[Actions\Action12\Params]
varname=STRING|"mail"
varvalue=STRING|"{Line(2)}"
Name=STRING|"//output variables"
[Actions\Action13\Params]
comment=STRING|"output variables"
[Actions\Action14]
[Actions\Action14\Params]
message=STRING|"line = {Line}"
[Actions\Action15]
[Actions\Action15\Params]
message=STRING|"{CustomerNum}"
[Actions\Action16]
[Actions\Action16\Params]
message=STRING|"{CustomerName}"
[Actions\Action17]
[Actions\Action17\Params]
message=STRING|"{Mail}"
[Actions\Action18]
Name=STRING|"Set variable ""first"" with value ""true"""
varname=STRING|"first"
varvalue=STRING|"true"
message=STRING|"****************"
Name=STRING|"Text Loop"
destvar=STRING|"LINE"
line0=STRING|"{list}"
sourcetext=STRING|"1"
Name=STRING|"If Then //skip 1-st line"
value1=STRING|"{first}"
Name=STRING|"Set variable ""first"" with value ""false"""
varvalue=STRING|"false"
ActionID=STRING|"A_LOOP_CONTINUE"
Name=STRING|"Continue"
Name=STRING|"//set variables"
comment=STRING|"set variables"
This example stores each line as JSON object. JSOM is preferred if you use for more complex structures or arrays
ExternalName=STRING|"Task1417"
ID=INTEGER|1343852539
Name=STRING|"Set variables from list (json)"
ToLog=INTEGER|2
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Name=STRING|"Set variable ""json:Customer.Number"" with value ""{Line(0)}"""
varname=STRING|"json:Customer.Number"
Name=STRING|"Set variable ""json:Customer.Name"" with value ""{Line(1)}"""
varname=STRING|"json:Customer.Name"
Name=STRING|"Set variable ""json:Customer.mail"" with value ""{Line(2)}"""
varname=STRING|"json:Customer.mail"
[Actions\Action14]
Name=STRING|"Log Message //line"
[Actions\Action15]
Name=STRING|"Log Message //full"
message=STRING|"Customer = {customer}"
[Actions\Action16]
Name=STRING|"Log Message //number"
message=STRING|"{json:Customer.Number}"
[Actions\Action17]
Name=STRING|"Log Message //Name"
message=STRING|"{json:Customer.Name}"
[Actions\Action18]
Name=STRING|"Log Message //mail"
[Actions\Action18\Params]
message=STRING|"{json:Customer.mail}"
[Actions\Action19]
Post
by Rukbunker » Thu Sep 02, 2021 12:47 pm
Many thanks for cooperating!
However, I see the variables in your script are separated by a space and not a comma or semicolon, or do I miss something?
Post
by Oleg » Thu Sep 02, 2021 2:53 pm
...I see the variables in your script are separated by a space and not a comma or semicolon,...
Where? Maybe I don't understand you...
Explain in more details, please
Post
by Rukbunker » Thu Sep 02, 2021 3:09 pm
It spits out the variables divided by a space, not a "," or a ";"
Post
by Oleg » Thu Sep 02, 2021 4:04 pm
You gave me CSV text wit COMMA separated lines
The CSV looks like:
Also pay attention that strings with spaces or commas "," must be quoted in standard comma-separated string. Like this:
123456,"Customer with spaces",robotask@robotask.com
Look at new example below. I added
Split text action to convert line to standard comma-separated line
ToLog=INTEGER|2
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
varvalue=STRING|"Customernumber,CustomerName,Mail{EOL}000001,Robotask,info@dummymail.hay{EOL}000052,YankyDoodle,dontwrite@mail.co.uk.br.tr{EOL}000125;Customer with spaces in it's name and semicolon as divider;robotask@robotask.com"
[Actions\Action14]
[Actions\Action15]
message=STRING|"raw line = {RawLine}"
[Actions\Action16]
[Actions\Action17]
[Actions\Action18]
[Actions\Action19]
[Actions\Action19\Params]
[Actions\Action20]
destvar=STRING|"RAWLINE"
Name=STRING|"Split Text //convert to standard comma-separated string"
colon=STRING|"0"
comma=STRING|"1"
other=STRING|"0"
quote=STRING|"2"
semocolon=STRING|"1"
space=STRING|"0"
spaceasone=STRING|"0"
string=STRING|"{rawline}"
tab=STRING|"0"
variable=STRING|"line"
Post
by Rukbunker » Fri Sep 03, 2021 1:34 pm
That was the solution! Many thanks for your time !
