Mouse position
VicFan
Mouse position
Post by VicFan »
It would be really helpful to add a function to save the current mouse position (absolute X-Position and absolute Y-Position) into 2 variables. This could allow the script to return the mouse to whatever position it has previously been at by using the Mouse Move function with those 2 variables.
Re: Mouse position
You can do this right now.
Look at my example
To run the task press CTRL+ALT+P. the task saves the mouse position and restores at the end of task.
CatID=INTEGER|1163085779
ExternalName=STRING|"Task1179"
ID=INTEGER|-273600315
Name=STRING|"Save mouse position"
Name=STRING|"Set variable ""xpos"" with value ""{MouseX}"""
varname=STRING|"xpos"
varvalue=STRING|"{MouseX}"
Name=STRING|"Set variable ""ypos"" with value ""{MouseY}"""
varname=STRING|"ypos"
varvalue=STRING|"{MouseY}"
Name=STRING|"Show ""Press OK to show saved mouse position"""
msg0=STRING|"Press OK to show saved mouse position"
message=STRING|"Saved position x={xpos}; y={ypos}"
Name=STRING|"Show ""Saved position"""
msg0=STRING|"Saved position"
msg1=STRING|"x = {xpos}"
msg2=STRING|"y = {ypos}"
msg4=STRING|"press OK to restore position "
msgcount=STRING|"5"
ActionID=STRING|"A_MOUSE_MOVE"
Name=STRING|"Move"
dx=STRING|"{xpos}"
dy=STRING|"{ypos}"
mode=STRING|"0"
Name=STRING|"Ctrl+Alt+P"
UniqueID=INTEGER|-334513961
hotkey=STRING|"49232"
VicFan
Re: Mouse position
Post by VicFan »
It is during the task that I want to save the mouse position, not just restore the mouse to position before the script executes.
Here is a use case: during execution the script an object is deleted and I want to create another object of a different type in same place as the original. The script can't do that because the object no longer exists that it found the original position to begin with.
VicFan
Re: Mouse position
Post by VicFan »
Sorry, please delete my reply asking how to do it during the script. I just read your reply and didn't try the code. Sorry
