email error
Robert Daggar
email error
Post by Robert Daggar »
I have set up an email send action that worked ok but now generates a "socket error 10022". Any ideas as to how I can eliminate this problem?
email error
Probably you've specified incorrect host name or port. This error shows that RoboTask can't connect to server. Please, check parameters on "SMTP Server" tab.
Robert Daggar
email error
I have further monitored this task. The email SEND works someties and not others. I am unable to determine any pattern to the failures. However, by definition the setup must be correct for the task to work some of the time.
Is it possible that another program is grabbing the socket? If so, what could it be - Outlook is always running when I execute this task.
email error
Probably, your SMTP server is not accessible sometimes by some reason.
email error
Try to test connection to server by "Ping Host" action before sending email.
