Something simple which I ...
robotasker
Post by robotasker »
Something simple which I ... cant even get it to work @@
Hello all, umm I was trying to make this program that "auto-reconnect" (so I don't hav to connect manually :P)
the story is......because when i am online....(downloading, surfing, etc) in a certain amount of time(~10mins), my isp will disconnect me and i will have to reconnect and get a new session key to continue.
the way i was thinking to overcome this is to set a cyclic event for 10 mins. Starting by turning on IE, then have to continuesly (a loop)to check for a popup dialog box (if that popup dialog box appears, it means that I am disconnected), then i will hav to do bla bla bla...( I can work on from that point)
Well, how do I get the "If then" and etc to work?
So the steps are: turn on IE, then looping to check for a dialog box, and if it appears then.........
Appreaciate any Help, Thank You
You detect internet connection in a very complicated manner.
You can use "Connection monitor" event or check connection via "Check Connection" action each 30-60 sec.
Also you may use "Ping Host" action for determining quality of connection.
See small example how to use "ping".
Save text of task to file and use menu "Task | Import" to import into RoboTask
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|782314203
ExternalName=STRING|"Task366"
ID=INTEGER|1820826400
Name=STRING|"Ping example"
Action14=FOLDER
Action15=FOLDER
ActionID=STRING|"A_INET_PING"
Name=STRING|"Ping robotask.com"
default=STRING|"-1"
host=STRING|"robotask.com"
timeout=STRING|"10000"
variable=STRING|"PING_TIME"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Show ""Good connection!"""
msg0=STRING|"Good connection!"
[Actions\Action14]
[Actions\Action15]
Name=STRING|"Remove variable ""PING_TIME"""
[Actions\Action15\Params]
varname=STRING|"PING_TIME"
type=STRING|"1"
value1=STRING|"{ping_time}"
value2=STRING|"-1"
Name=STRING|"Show ""Conection is downed!"""
icon=STRING|"3"
msg0=STRING|"Conection is downed!"
Name=STRING|"Else"
operator=STRING|"2"
type=STRING|"1"
value2=STRING|"5000"
Name=STRING|"Show ""Bad connection!"""
icon=STRING|"0"
msg0=STRING|"Bad connection!"
Name=STRING|"Else"
operator=STRING|"2"
type=STRING|"1"
value2=STRING|"1500"
Name=STRING|"Show ""Poor connection!"""
icon=STRING|"0"
msg0=STRING|"Poor connection!"
robotasker
Cool got it
Umm...one more newb question
eg
How do it make the popup message to autoclose in like 1 sec of time? Cuz I dunt wanna keep pressing "OK"
It's only an example for demonstration.
If you don't want to see the dialog box with message you can replace dialog with "Log Message" action. In this case the message will be placed into log of task.
Also, you can simply turn off this step or remove it.
robotasker
thx  I turned it off
I will go experiment with rest of the commands now....hehe thx again
