Robotask 6.0 on windows 10
richard.bessey
Post by richard.bessey »
I have an old copy of Robotask 6 that has worked perfectly for me until now.
I am running windows 10 and it was working correctly but suddenly when I start the application, it flashes on the screen and then disappears.
I assume this is caused by a windows update but I am not certain.
I have tried re-installing and still encounter the same problem.
Anyone have any tips?
Re: Robotask 6.0 on windows 10
Hm-m-m... I installed version 6.0 on Windows 10 machine with latest updates. It works!
maybe.
To re-install you must remove RoboTask first: uninstall and remove all binaries manually if it's necessary
Then, install it again. You can find all previous versions here.
Also one recommendation:
go to system registry:
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FeatureUsage\AppSwitched
and remove all values related to RoboTask and its utilities.
I discovered this solution completely by accident. It was another problem, but maybe this helps you.
