opening chrome shortcut
sahiyan
Post by sahiyan »
How do you open a shortcut? I used Run Program/Open to open chrome shurtcut (profile shortcut) but it just launches the application and not the link with its parameters.
shortcut address : "C:\Program Files (x86)\Google\Chrome\Application\chrome.exe" --profile-directory="Profile 21"
but robotask open this address: "C:\Program Files (x86)\Google\Chrome\Application"
Re: opening chrome shortcut
When you select a shortcut then the action editor get application name from it.
You can specify the fill path to LNK file
for example:
C:\Users\MyUserName\Desktop\MyTest.lnk
Or run Chrome with parameters directly
chrome with params.png (18.69 KiB) Viewed 3975 times
