Regex - Ignore piece of text
Hello Oleg,
We execute a command line tool which exports possible errors to a text file, errors.txt. The content of these file can be "19 55 A4 F6 88", or just "88". The thing is, I should program Robotask in a way it DOESN'T take action when 88 occurs, but it SHOULD respond when any other error occurs. The errors can occur in different orders, so "55 88 7F" is also possible.
If the file is empty (= 0 kB) it shouldn't do anything, that part is already covered.
I've played around with RegEx, like \b(?!88)\b\S+
What is the best approach in this? A RegEx loop or match in combination with if / else's?
If the errorfile is empty = No action (DONE)
If errorfile ONLY contains "88" = No action
If error has errors, including 88 = Ignore 88, proceed with others
Re: Regex - Ignore piece of text
look at my task
It extracts all error codes from string in the loop and skips the error 88
So you get your algorithm:
if empty -> nothing
if 88 only -> nothing
if many errors -> process all errors except 88
CatID=INTEGER|1075658632
ExternalName=STRING|"Task1137"
ID=INTEGER|-1406772994
Name=STRING|"Extract error codes"
Action14=FOLDER
Name=STRING|"Set variable ""str"" with value ""55 88 7F"""
varname=STRING|"str"
varvalue=STRING|"55 88 7F"
operator=STRING|"7"
value1=STRING|"{txt}"
Name=STRING|"Show ""No errors to process"""
msg0=STRING|"No errors to process"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Show Text"
[Actions\Action13\Params]
autoclose=STRING|"0"
fromfile=STRING|"1"
line00000000=STRING|"Errors are:"
line00000001=STRING|"{txt}"
linecount=STRING|"2"
timeout=STRING|"10"
[Actions\Action14]
Name=STRING|"Set variable ""txt"" with value """""
varname=STRING|"txt"
ActionID=STRING|"A_REGEXP_LOOP"
Name=STRING|"RegExp Loop"
anchored=STRING|"0"
extended=STRING|"0"
line00000000=STRING|"{str}"
multiline=STRING|"0"
noautocapture=STRING|"0"
pattern=STRING|"([A-F0-9]{2})"
savelengths=STRING|"0"
saveoffsets=STRING|"0"
singleline=STRING|"0"
ungreedy=STRING|"0"
useexternal=STRING|"0"
variable=STRING|"err"
Name=STRING|"If Then // err=88 - skipped"
value1=STRING|"{err(0)}"
value2=STRING|"88"
ActionID=STRING|"A_LOOP_CONTINUE"
Name=STRING|"Continue"
Name=STRING|"Else"
Name=STRING|"Set variable ""txt"" with value ""{txt}{err(0)}{EOL}"""
varvalue=STRING|"{txt}{err(0)}{EOL}"
And again, you've pushed me into the right direction. My way of thinking was too different (wrong?) from your approach. Never thought of this setup!
Many thanks!
