Blank Screen on Python Script Tool
george
Post by george »
Hi, I've been using the Python Script tool but the window won't let me input any data. The first time it worked great and ran the script but now I can't edit it. I've tried creating new tasks and even reinstalling Robotask but it shows just a blank unwritable screen (see attached file).
How can I fix it?
Thanks.
Python Script Windows
Screen Shot 2021-05-04 at 06.21.47.png (160.27 KiB) Viewed 26007 times
AlexeySurkis
Re: Blank Screen on Python Script Tool
Post by AlexeySurkis »
Hi, try to do the following:
- run regedit.exe
- open the HKEY_CURRENT_USER\SOFTWARE\TaskAutomation\RoboTask\Settings\Plugins\ScriptTools key
- remove the TfrmScriptActionBase and TfrmPythonScriptAction subkeys
Best regards,
Alexey Surkis
george
Post by george »
That fixed it, thanks Alexey!! :D
george
Post by george »
Everytime I open and close a Python Script Action to edit it, the lower margin starts getting closer to the upper margin; so when I reach aprox. 6 edits it no longer shows the code window.
I don't know if it happens just to me or it's a bug.
Anyway, I can fix it deleting the TfrmPythonScriptAction on regedit for now. :?
It seems we have found the problem
The couple questions:
  • - What scale of RoboTask do you use? (Options->Scale)
    - What system size of text do you use (context menu on desktop -> Display settings)
We will release the patch in nearest time
george
Post by george »
Hi Oleg, the scale I'm using on Robotask is 125% and the text size is 100%
For now I'm able to make it work blocking permissions to the edition of that subkey in specific.
