Out of memory message
ivan.ulens@vcst.be
Post by ivan.ulens@vcst.be »
Dear,
I receive an out of memory message. What can I do about it?
It is in a flow to create a XML-File and the input-File is big.
Re: Out of memory message
... and the input-File is big.
How large is the input file?
ivan.ulens@vcst.be
File contains 10482 rows (1.556 kn)
ivan.ulens@vcst.be
Hi Oleg,
any idea for a solution?
regards,
Ivan
Maybe it's possible to optimize your task
But I want to see the task and the files used
Send them to me please, by email, if possible: oleg@robotask.com
ivan.ulens@vcst.be
Dear Oleg,
Files sent.
regards,
Ivan
I'm sorry. I think that your algorithm is incorrect at all.
XML file size will grow exponentially and you will get "Out of memory" inevitably
I made some changes in the task and test it now
ivan.ulens@vcst.be
Dear,
already some thoughts?
regards,
Ivan
I have sent the corrected task to you at 2021-05-11
Have you received it? check spam folder please
below the task. It works with your file you sent (1.5M and 10K lines)
My answer earlier:
I think that you are using incorrect algorithm at all.
I tried to build XML for first 100 lines (see attachment)
I think It's doesn't correspond to your text file (analyze it carefully). You added "AuxiliarCtas:Cuenta" nodes to XML at each iteration. This is incorrect.
Therefore I get 1000 lines XML text from first 100 lines of source text. No wonder you got an error "Out of memory"
I'll try to correct your algorithm
I tested my task (see below)
It created XML file (10578 lines size 1656K) without errors
I wrote some comments in the task. Let me know if you need any explanation
CatID=INTEGER|1163085779
ExternalName=STRING|"Task1371"
ID=INTEGER|2103539701
Name=STRING|"text XML ""out of memory"""
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
Action21=FOLDER
Action22=FOLDER
Action23=FOLDER
Action24=FOLDER
Action25=FOLDER
Action26=FOLDER
Action27=FOLDER
Action28=FOLDER
Action29=FOLDER
Action30=FOLDER
Action31=FOLDER
Action32=FOLDER
Action33=FOLDER
Action34=FOLDER
Action35=FOLDER
Action36=FOLDER
Action37=FOLDER
Action38=FOLDER
Action39=FOLDER
Action40=FOLDER
Action41=FOLDER
Action42=FOLDER
Action43=FOLDER
Action44=FOLDER
Action45=FOLDER
Action46=FOLDER
Action47=FOLDER
Action48=FOLDER
Action49=FOLDER
Action50=FOLDER
Action51=FOLDER
Action52=FOLDER
Action53=FOLDER
Action54=FOLDER
Action55=FOLDER
Action56=FOLDER
Action57=FOLDER
Action58=FOLDER
Name=STRING|"Set variable ""LITFILNAME1"" with value ""C:\temp\xml\MX_AUXILIARCTAS_D20210504_T070015.TXT"""
varname=STRING|"LITFILNAME1"
varvalue=STRING|"C:\temp\xml\MX_AUXILIARCTAS_D20210504_T070015.TXT"
Name=STRING|"STR Extract"
amount=STRING|"12"
from=STRING|"1"
source=STRING|"{STRORG}"
variable=STRING|"STRFIRST"
value1=STRING|"{STRFIRST}"
value2=STRING|"AUXILIARCTAS"
Enabled=INTEGER|0
Name=STRING|"Show ""1ste niveau: {STRFIRST}"""
[Actions\Action12\Params]
msg0=STRING|"1ste niveau: {STRFIRST}"
[Actions\Action13\Params]
amount=STRING|"15"
from=STRING|"13"
[Actions\Action14]
ActionID=STRING|"A_STR_TRIM"
Name=STRING|"STR Trim"
[Actions\Action14\Params]
custom=STRING|"0"
eol=STRING|"0"
lead=STRING|"1"
source=STRING|"{STRFIRST}"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
variable=STRING|"RFC"
[Actions\Action15]
[Actions\Action15\Params]
amount=STRING|"2"
from=STRING|"28"
variable=STRING|"Mes"
[Actions\Action16]
[Actions\Action16\Params]
amount=STRING|"4"
from=STRING|"30"
variable=STRING|"Anio"
[Actions\Action17]
[Actions\Action17\Params]
amount=STRING|"2"
from=STRING|"34"
variable=STRING|"TipoSolicitud"
[Actions\Action18]
ActionID=STRING|"A_XML_CREATENODE"
Name=STRING|"XML Create Node (AuxiliarCtas)"
[Actions\Action18\Params]
att00000000=STRING|"RFC,{RFC}"
att00000001=STRING|"Mes,{Mes}"
att00000002=STRING|"Anio,{Anio}"
att00000003=STRING|"TipoSolicitud,{TipoSolicitud}"
att00000004=STRING|"Version,1.3"
att00000005=STRING|"xsi:schemaLocation,""http://www.sat.gob.mx/esquemas/ContabilidadE/1_3/AuxiliarCtas http://www.sat.gob.mx/esquemas/ContabilidadE/1_3/AuxiliarCtas/AuxiliarCtas_1_3.xsd"""
att00000006=STRING|"xmlns:xsi,http://www.w3.org/2001/XMLSchema-instance"
att00000007=STRING|"xmlns:AuxiliarCtas,http://www.sat.gob.mx/esquemas/ContabilidadE/1_3/AuxiliarCtas"
attcount=STRING|"8"
name=STRING|"AuxiliarCtas:AuxiliarCtas"
txtcount=STRING|"1"
variable=STRING|"AuxiliarCtas"
[Actions\Action19]
Enabled=INTEGER|0
[Actions\Action19\Params]
attcount=STRING|"8"
name=STRING|"AuxiliarCtas"
txtcount=STRING|"1"
Name=STRING|"//new actions"
comment=STRING|"new actions"
[Actions\Action20]
ActionID=STRING|"A_FLOW_ELSEIF"
Name=STRING|"ElseIf Then"
[Actions\Action20\Params]
value2=STRING|"CUENTA......"
[Actions\Action21]
Name=STRING|"//new actions (moved from ELSE block)"
[Actions\Action21\Params]
[Actions\Action22]
Name=STRING|"If Then //Cuenta node already exists"
[Actions\Action22\Params]
operator=STRING|"8"
value1=STRING|"{Cuenta}"
[Actions\Action23]
ActionID=STRING|"A_XML_ADDCHILD"
Name=STRING|"XML Add Childnode (AuxillarCtas <- Cuenta)"
[Actions\Action23\Params]
child00000000=STRING|"{Cuenta}"
childcount=STRING|"1"
parent00000000=STRING|"{AuxiliarCtas}"
parentcount=STRING|"1"
[Actions\Action24]
Name=STRING|"Set variable ""Cuenta"" with value """" //clear Cuenta node"
[Actions\Action24\Params]
varname=STRING|"Cuenta"
[Actions\Action25]
[Actions\Action26]
Enabled=INTEGER|0
Name=STRING|"Show ""2de niveau: {STRFIRST}"""
[Actions\Action26\Params]
msg0=STRING|"2de niveau: {STRFIRST}"
[Actions\Action27]
[Actions\Action27\Params]
amount=STRING|"10"
from=STRING|"13"
[Actions\Action28]
[Actions\Action28\Params]
custom=STRING|"0"
eol=STRING|"0"
lead=STRING|"1"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
variable=STRING|"NumCta"
[Actions\Action29]
[Actions\Action29\Params]
amount=STRING|"70"
from=STRING|"23"
[Actions\Action30]
[Actions\Action30\Params]
custom=STRING|"0"
eol=STRING|"0"
lead=STRING|"1"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
variable=STRING|"DesCta"
[Actions\Action31]
[Actions\Action31\Params]
amount=STRING|"25"
from=STRING|"93"
variable=STRING|"SaldoIni"
[Actions\Action32]
[Actions\Action32\Params]
amount=STRING|"25"
from=STRING|"118"
variable=STRING|"SaldoFin"
[Actions\Action33]
Enabled=INTEGER|0
Name=STRING|"XML Create Node (Cuenta)"
[Actions\Action33\Params]
att00000000=STRING|"NumCta,{NumCta}"
att00000001=STRING|"DesCta,{DesCta}"
att00000002=STRING|"SaldoIni,{SaldoIni}"
att00000003=STRING|"SaldoFin,{SaldoFin}"
attcount=STRING|"4"
name=STRING|"AuxiliarCtas:Cuenta"
txtcount=STRING|"1"
variable=STRING|"Cuenta"
[Actions\Action34]
[Actions\Action34\Params]
attcount=STRING|"4"
txtcount=STRING|"1"
[Actions\Action35]
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
[Actions\Action36]
Enabled=INTEGER|0
Name=STRING|"Show ""3de niveau: {STRFIRST}"""
[Actions\Action36\Params]
msg0=STRING|"3de niveau: {STRFIRST}"
[Actions\Action37]
[Actions\Action37\Params]
amount=STRING|"8"
from=STRING|"13"
variable=STRING|"Fecha"
[Actions\Action38]
[Actions\Action38\Params]
amount=STRING|"8"
from=STRING|"21"
variable=STRING|"NumUnIdenPol"
[Actions\Action39]
[Actions\Action39\Params]
amount=STRING|"70"
from=STRING|"29"
Name=STRING|"Set variable ""num"" with value ""0"""
varname=STRING|"num"
varvalue=STRING|"0"
[Actions\Action40]
[Actions\Action40\Params]
custom=STRING|"0"
eol=STRING|"0"
lead=STRING|"1"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
variable=STRING|"Concepto"
[Actions\Action41]
[Actions\Action41\Params]
amount=STRING|"25"
from=STRING|"99"
variable=STRING|"Debe"
[Actions\Action42]
[Actions\Action42\Params]
amount=STRING|"25"
from=STRING|"124"
variable=STRING|"Haber"
[Actions\Action43]
Enabled=INTEGER|0
Name=STRING|"XML Create Node (DetalleAux)"
[Actions\Action43\Params]
att00000000=STRING|"Fecha,{Fecha}"
att00000001=STRING|"NumUnIdenPol,{NumUnIdenPol}"
att00000002=STRING|"Concepto,{Concepto}"
att00000003=STRING|"Haber,{Haber}"
attcount=STRING|"4"
name=STRING|"AuxiliarCtas:DetalleAux"
txtcount=STRING|"1"
variable=STRING|"DetalleAux"
[Actions\Action44]
[Actions\Action44\Params]
attcount=STRING|"4"
name=STRING|"DetalleAux"
txtcount=STRING|"1"
[Actions\Action45]
Enabled=INTEGER|0
Name=STRING|"Show ""Node: {DetalleAux}"""
[Actions\Action45\Params]
msg0=STRING|"Node: {DetalleAux}"
[Actions\Action46]
Enabled=INTEGER|0
Name=STRING|"Show ""Node: {Cuenta}"""
[Actions\Action46\Params]
msg0=STRING|"Node: {Cuenta}"
[Actions\Action47]
Name=STRING|"XML Add Childnode (Cuenta <- DetalleAux)"
[Actions\Action47\Params]
child00000000=STRING|"{DetalleAux}"
parent00000000=STRING|"{Cuenta}"
[Actions\Action48]
Name=STRING|"//removed action ""XML Add Childnode (AuxillarCtas <- Cuenta)"" Moved above"
[Actions\Action48\Params]
[Actions\Action49]
Name=STRING|"Text Loop"
destvar=STRING|"STRORG"
file=STRING|"{LITFILNAME1}"
line0=STRING|"""George Orwell"",1984"
line1=STRING|"""George Orwell"",""Animal Farm"""
line2=STRING|"""J.K. Rowling"",""Harry Potter and the Sorcerer's Stone"""
line3=STRING|"""Suzanne Collins"",""The Hunger Games"""
line4=STRING|"""William Shakespeare"",""Romeo and Juliet"""
linecount=STRING|"5"
sourcetext=STRING|"0"
[Actions\Action50]
Enabled=INTEGER|0
[Actions\Action50\Params]
operator=STRING|"3"
type=STRING|"1"
value1=STRING|"{num}"
value2=STRING|"100"
[Actions\Action51]
Enabled=INTEGER|0
Name=STRING|"Break"
[Actions\Action52]
Enabled=INTEGER|0
[Actions\Action53]
[Actions\Action54]
[Actions\Action54\Params]
[Actions\Action55]
[Actions\Action55\Params]
operator=STRING|"8"
value1=STRING|"Cuenta"
[Actions\Action56]
[Actions\Action56\Params]
[Actions\Action57]
[Actions\Action58]
ActionID=STRING|"A_XML_SAVE"
Name=STRING|"XML Save"
[Actions\Action58\Params]
filename=STRING|"C:\temp\xml\{LITFILNAME2}.xml"
ifexists=STRING|"1"
xml00000000=STRING|"{AuxiliarCtas}"
xmlcount=STRING|"1"
incement=STRING|"1"
vaiable=STRING|"num"
message=STRING|"{num}"
Name=STRING|"Set variable ""LITFILNAME2"" with value ""{ExtractFileName({LITFILNAME1})}"""
varname=STRING|"LITFILNAME2"
varvalue=STRING|"{ExtractFileName({LITFILNAME1})}"
